Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Need clear plastic cover for front of door
I am looking for a replacement round plexiglass piece for the front of the door on my bosch nexxt essence washer
I have one. My new Bosch washer came 2 months ago and I removed it immediately.
The problem is that it arrived scratched up somewhat, which is another reason I removed it as this will only get worse with a plastic cover.
The cover also makes it harder to see into the machine while it's in operation.
To be honest, I'm not sure why you would want it on there, but if you really need one then mine is available.
Posted on Jun 16, 2009
How to replace drain pump?
take out the plug
you need to remove the front cover first remove kick plate.then take out soap dish.. remove the door seal.. take of door lock..take 3 screws now remove the cover the pump can now be removed
Aug 19, 2014 | Bosch WFMC2100UC Nexxt Essence Washer
We have a Bosch Nexxt 100 Series Washer. The door lock is stuck and will not unlock. We have a load of clothes in the washer but are unable to get the door to unlock. I have tried unplugging the unit,...
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch series 300 washer: E:04 error; how to remove pump cover
You can get that cover off, by prying it up at the bottom and spinning the thing clockwise. then there is a large hand turnable plug inside.
Once you turn it water will start leaking out, you'll have to get in and pull out the crud from the pump screen there to clear the jam. Good luck!
Apr 10, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt DLX washer-can't open round panel in lower front
Its easy to do, and no you dont need to be a tech. I use a small screww driver w/ the tip in the hole push it left or right until it comes loose. then just un screw the pump cover. be careful the edges are razor sharp.
Jan 24, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Is there a filter that I can clean out located behind the round cover on the lower right front of my Bosch Nexxt 500 series washer?  If so, how do I get the cover off?
just pop it off with a small srewdriver and yes you can get to the fluff filter through the round cover
when you open the filter there will be about two litres of water come out beware
Jan 21, 2009 | Bosch WFMC 3200 Front Load Washer
How do you replace the door seal on a Bosch Nexxt front load washer?
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch washer
This video will show you how to change a door seal on this bosch
Jul 06, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch Nexxt Essence Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
307 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
