Question about Canon PowerShot G2 Digital Camera
Need a calbe for Canon Posershot G2 LCD screen
  • Anonymous Mar 17, 2008
    I do have the same problem in my camera "canon powershot G2" where I see one of the LCD wire is cut when i tried to fix the problem. I need to know if i can get that part alone to repair my camera.
I was able to purchase a new USB cable for my G2 here:
(800) 278-4002
Posted on Apr 11, 2008
Posted on Mar 17, 2008
Blue screen , No sound also say no signal my other tv'a work on same calbe
both tvs has has out of signal, check your cable or call cable operator
good luck
Nov 28, 2010 | Astar LTV-32HBG 32 in. LCD Television
Clear mold insides lens of Canon G2/G5
Who found the mold? The lens cannot be disassembled by you. It must be done at a Canon service center and it will be expensive.
Jan 28, 2010 | Canon PowerShot G2 Digital Camera
The viewing screen on our Cannon Power Shot 8520 is not working. The camera still takes pictures and I can download them on the camera. I just can't see what I have taken. So I'm looking for the viewing...
Canon parts and repair service is excellent. All the parts of canon powershot is readily available in the market for reasonable price.
For your reference i am giving you the site where they take up these kind of problems.
the website is " ".
Replacing a broken or cracked LCD display screen:
  • Powershot A Series: $90 for most all models (a few dollars less on some)
  • Powershot S Series (S30 - S80, S100-S500, S1-IS, S2-IS): $90 for most models (a few dollars less on some)
  • Powershot SD200, SD300, SD400, SD630: $100 (the LCD for these models is more expensive)
  • All other Powershot SD Series models (including SD700IS and 800IS): $90
  • Powershot G2, G3: $90. Some other G series Powerhot models cost $10-20 more because of the higher parts cost.
The above price list is from the mentioned website.Hope my info is useful.
Sep 19, 2008 | Cameras
LCD monitor is blank
Canon would have to fix this for you. The fault may be the screen itself, or the LCD viewfinder drive IC on the camera's circuit board. In this case they will replace the circuit board.
Jerry G.
Dec 09, 2007 | Canon PowerShot G3 Digital Camera
Canon powershot G2
I just repaired my Canon G2 with the same symptom.  The internal PCB that you plug the external AC adapter is defective.  The numbers on the board are:
Oct 21, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
LCD screen turns off when back in body
We had a similar problem. If you remove the cover to the place where the LCD hinges, you will find two little wires broken off. These attach to a black touch sensor resting in the lcd screen. It comes out easily and without issue. WIth the two wires torn, the camera does not recognize that the LCD display has been turned around. It turns the screen off because it believes you have the LCD screen pointed inward towards the body of the camera. A small extension for the wires and a soldering iron solved that set of problems.
Sep 28, 2007 | Canon PowerShot G2 Digital Camera
Cannon G2
A Fubar - whats does that mean - but your camera looks like it is one. A new camera I suspect is the next thing to buy But check Canon customer support- they may have a remedy for 'Fubars'
Aug 04, 2007 | Canon PowerShot G2 Digital Camera
Lcd screen does turn on
This is a defective CCD problem that is known to Canon. They will replace the defective part for FREE. Go here for more details:
Nov 10, 2006 | Canon PowerShot A75 Digital Camera
White LCD on my canon
Hi: I think you have broken (accidentaly with the fall) the cable with several wires that connect the LC display. My real advice is that you take your camera to a store were they can give you direct support desmanteling the camera and replacing the cable or fixing it. However, Zair already had a problem like yours and the best solutions was given by BowerR64. You can consult on the following page:,p294056/Canon-PowerShot-G2-Digital-Camera.aspx (just copy and paste on the address bar) ;) Regards
May 21, 2006 | Canon PowerShot G2 (Black) Digital Camera
Canon powershot G2
Hi: It turns out that one of the wires connecting the LCD screen with the camera body probably is broken. It is a simple to remove the LCD cover and reconnect the wire, but it requires manipulating very small objects. The clip that you must re-insert the wire into is scarcely 1mm x 4mm. I recommend a bright light, magnifying glass, tweezers, and a very small phillips screwdriver. It might also be possible to aquire a replacement cable from Canon. E-mail them... Regards
May 08, 2006 | Canon PowerShot G2 Digital Camera
Canon PowerShot G2 Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
