Question about Air Tools & Compressors
Tooo quiet now, no pressure
AIR Compressor -running normally, quite load - then loud pop noise - now about 1/2 as noisey and no pressure builds. what is the likely cause or repair? thank you
  • 163 Answers
Sounds like a line or compressor blew. Hard to say. Look for wet spots on the lines for A/C oil leaking.
Posted on May 25, 2009
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Similar to another persons question...have a circa 1995 cambell hausfeld piston type compressor, has been great for past 17 years. it was building pressure, albeit the source at the tire fitting...
Woody:
Your compressor is losing pressure somewhere... check both ends of the air tube between the compressor head and the tank. The loud pop may have been the packing at one end or the other. You'll have to remove the head again to remove the air tube, but I believe your problem is the pressure seal at one end of the tube or the other.
Mar 11, 2013 | Air Tools & Compressors
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Air pressure iI gone but motor works haappened all
As I understand it, your air compressor motor runs but you can not build pressure. Is this correct?
Two main reasons:
#1: Your safety valve popped and the air is going straight out the safety valve. You should be hearing a loud hissing noise if this is the case. Press the safety valve back in and you should build pressure. Many such valves have a ring on them (to help you find them). It should be very near the pressure switch.
#2: You have a broken reed valve. A reed valve opens or closes based on the pressure it is under. It allows air to enter the tank on the compression stroke, but will not let it out of the tank as the piston strokes up and down. If it is broken or stuck open, you cannot build pressure.
and #3, a after thought, no extra charge ;-) The rings on the piston may have broken.
For #2 and #3, it will be necessary for you to remove the head to inspect.
Find repair parts at the Coleman web site.
I hope this helps you solve your trouble.
Thanks for your question at FixYa.com
If you found this helpful, please vote.
Thanks
Dec 24, 2009 | Coleman Powermate 4 Gallon Air Compressor
My fan runs extremely loud on and off
It is set up to run if CPU gets warm/hot. Quiet normal.
If it didn't you would son know. One Cooked CPU with Chips. Expensive tak Away.
Some fans are noisey. You could go to the expense and have a replacement???
Nov 16, 2009 | HP Pavilion dv2915nr Notebook
My new frigidaire refrigerator model# FRT18S6AWX is unusually noisey . It makes gurgleing sound and it last for 10 seconds . it does this throughout the day once every half hour. We reported it and were...
hi, this is not normal at all. this is a manufacturing flaw the resides in the compressor build. there is way to much pressure being produced threw the lines. the compressor regulator seems to be flawed in its design. i would recommend purchasing a aftermarket compressor Assembly for this unit. the noise itself is a dead give away for flawed compression in the core Assembly.
Mar 11, 2009 | Frigidaire FRS26R4A Side by Side...
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
There is a loud noise coming from my engine ..sometimes..
oh ok, you probably have air shocks and that is the compressor running... makes sense that it sounds with the engine off... it should not be a loud sound though, normally it's quite quiet and you only hear a faint noise... if it is that loud it's probably a bad compressor
Jan 13, 2009 | 2003 Lincoln Navigator
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Air Tools & Compressors Logo
62 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
