Question about Jandy PHP High Head Pump 2 HP Up rated
Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
My Jandy pool pump will not prime it is a Plus HP model PHPM 2.0
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    If you remove the basket from the pump you can check the water inlet with a finger or two, sometimes small particles of debris will pass thru the basket and get lodged in the water intake... also check the o-ring gasket around the lid....be sure it's clean.. lastly, pour a bucket of water in the basket before closing it back up snug and starting the pump... does this help? let me know...
  • David Spradling
    David Spradling Apr 16, 2016
    make sure oring on top is ok if ok check intake union if loose will not prime
    Problem Solver:
  • 16 Answers
Make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
I need a motor end cover, where can I get one? Thank you!
Jacuzzi (Carvin) Magnum, Force & Plus pump parts are hard to find.
Here is a link to our site which has a parts explosion/diagram for those pumps.
Jacuzzi Magnum, Magnum Plus, and Magnum Force Pumps
Jun 08, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
I can't get the impeller off. It doesn't have a screw and I can lock the shaft and try to turn it counter clockwise, but it will not budge.
there is most likely corrosion in the threads between the impeller and the motor shaft. You will need an impeller wrench to get enough torque to spin it loose., you may have to replace the impeller if it is excessively corroded as it may be cracked as well.
Nov 06, 2010 | Jandy POOL PUMP IMPELLER ASSY PLUS HP...
Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
May 02, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
Pool pump starts and stops
The thermal cutout is turning it off, then it turns on after it cools. When it runs does it pump water? The pump may be dragging from a bad bearing or a clogged impeller. Make sure the suction filter is clean. I would suggest hiring a pro pump company to diagnose the problem further.
Please mark helpful if it was. Thanks
Jul 08, 2009 | Jandy In-Ground Plus HP Pump
Pump starts and stops after few minutes
Sounds like your motor is overheating, This is a sign of windings going bad and sorry to say you will probally have to replace the motor.
May 18, 2009 | Jandy In-Ground Plus HP Pump
Jandy PHP High Head Pump 2 HP Up rated Logo
1,272 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
