Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Can the mighty mouse be named a specific name?
Can the Miight Mouse be named instead of it being called -"mighty mouse #1?
How do I keep the mouse cursor from jumping around?
  1. Open Mouse Properties by clicking the Start button. , and then clicking Control Panel. In the search box, type mouse, and then click Mouse.
  2. Click the Pointer Options tab, and then do any of the following:
  3. Click OK.
Jun 16, 2017 | The Computers & Internet
Mighty Mouse won't scroll down
1-turn mouse on back
2-there is a cover that holds the roller in place turn and remove
3- put roller and cover to the side
4-look inside there is a wheel and a bar
5-on the bar you will see some accumulation of dust and string, hair etc...
6-remove with eyebrow remover
7- put back roller and cover
Dec 19, 2007 | Apple Mighty MA086LL/A Mouse
I have the wireless optical mouse blue x08-72982. I can't find the USB connector. What do I buy from Microsoft? What is the name of it?
You will have to buy a whole new wireless mouse. The USB is hard coded for the mouse to a specific ID / frequency. You may find one that works, but it will be like a needle in a haystack and the USB receiver would cost almost as much as a new mouse.
Chris
Jul 07, 2011 | Microsoft Wireless Optical USB/PS2 Mouse...
I do not have the wireless mouse driver CD instalation
hi there,
Most wireless mouse does not require a specific driver for it to work.
But if your mouse requires one and you don't have a cd, if you can provide the manufacturer name and the model number of your mouse it would be helpful to locate a driver that we can download from the internet.
Thanks!
Jun 25, 2011 | Computers & Internet
I am using imac 24
Make sure that BlueTooth is turned on and is discoverable. (System preferences OR via the Bluetooth icon near the time-machine clock in the menu bar. Disconnect your wired mouse and wait a moment or two. You should get a message that no mouse is connected. Switch on your mighty mouse and wait a moment or two.
You should get a message that a mighty mouse has been detected - then follow the on screen instruction.
That's all there is to it.
Sep 14, 2009 | Apple iMac 24" Desktop
Elimnate mouse
You are talking about the mouse-pad or also called track-pad, I don't think we have a spanish name for it. To disable clicking with your mosuepad (a.k.a. tapping) go into your control panel mouse options and you should be able to find an option that reads "enable tapping", just unchech the selection box next to it to disable this option.
Jun 23, 2009 | HP Pavilion dv1000 Notebook
Green light on Mighty Mouse blinks two times
Since I posted "have the same problem" I found out what that problem was for me: Mighty Mouse is Bluetooth enabled, and my Bluetooth was off. That was all!
Mar 11, 2009 | Apple Mighty MA086LL/A Mouse
Mighty mouse not working
Same thing happened to me. I finally ended up with blue tooth telling me it could not detect my mouse and it had to find it. You might check your mouse settings in blue tooth.
Feb 20, 2008 | Apple Mighty MA086LL/A Mouse
Screen goes blank when I move the mouse
please be specific, your question is not understood properly??
Oct 26, 2007 | Dell E173FP 17" LCD Monitor
Dead Mouse
Try different USB jack. Try fresh batteries. Re-install software.
Sep 22, 2007 | Logitech 9311570403 Mouse
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
113 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
