Question about Maytag Washing Machines
Won't spin on spin cycle, smells of something burning.
Doesn't spin even when wet clothes removed; smells of something burning. 14 years old; good till now.
  • 11,896 Answers
Sounds like the belt or the tub bearings are shot. It is likely that the motor is spinning and the tub is not, causing the belt to burn.
Posted on May 25, 2009
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Washing machine spin cycle not working properly
Its the belt. Easy fix. Lift the top by sticking a screwdriver into the gap between the front panel and top panel. There are two "tabs" you need to push in while lifting the top front up. Then raise the front up a bit off the ground with blocks to take out the two phillips screws near the bottom (front). Then slide the front panel down. The belt is on the bottom. simple to remove from below the pully. not sure the belt type to replace with.
Feb 21, 2010 | Washing Machines
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Tub not working in spin cycle
Replace the brake/clutch on the transmission.
You can DIY.
May 25, 2009 | Kenmore 24922 Top Load Washer
Spin cycle not completely spinning out
Could be something stuck in the pump. Could be a bad belt.
This brand eats belts if the tub is overloaded even occasionally.
Remove the front panel and inspect the belt. Any glazing on the belt it should be replaced.
Remove and check the pump while you are there.
May 19, 2009 | Westinghouse Washing Machines
Leaking tub seal, slow spin cycle
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Won't spin with clothes in it.
sounds like a tired washer, it may be cheaper to purchase another for a couple hundred bucks
Jun 14, 2008 | GE WBSR3140DW Top Load Washer
Washing Machine Problem
if this is a sears or roper or whirlpool unit then check the direct drive coupling, if it sound like it should be spinning but doesn't
May 17, 2008 | Washing Machines
Drying cycle runs but does not dry clothes
more than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
Nov 23, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
330 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
