Question about Saeco Rio Vania Group 4 Espresso Machine
Just started blowing the breaker. Late in the day so I turned it off.
My Rio 4 Group just started blowing the breaker this afternoon after a long day pulling shots. What can I do? I shut it down.
    President:
  • 1,618 Answers
4 grp Rio, probably running on a 50Amp breaker. Check the electrical connections on the pump(if you model has an internal pump it would be above the switch there is a 3 connector bridge.
Check the switch, there may be loose connection, also check the plug and receptacle.
Check the element connections that would be the most likely suspect for a breaker blow.
Check to make sure that nothing else is on the same breaker as the machine.
Posted on May 26, 2009
Kia rio electrical
Buy a voltmeter and get a wiring diagram, or get a different car.
You can find a wiring diagram here:
Jan 23, 2014 | Cars & Trucks
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Bake and Broil elements quit working
Could be both elements, control board cause usually both elements don't go out simutaneously, or even just your breaker. check for continuity on elements unplugged of course.... and 220v at plug. also check for burnt wires to elements. some models have a cavity high-limit switch located on back for safety. check for continuity on this if you have such...hope this helps
Sep 05, 2012 | Ovens
Can I set the time of the day that a Hoover "Frost
Yes you can. if you know where the defrost timer is and how to turn it all you have to do is get up in the middle of the night say 3 or 4 in the morning and set the defrost timer, it will defrost that time everyday. Hope this helps. Wally
Sep 17, 2011 | Hoover Refrigerators
Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
Jul 17, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Sometimes it blows cold, sometimes it doesnt.
The coils that are located right behind the filter need to be cleaned extremely well. You can purchase a spray from your local hardware dealer that can clean the coils. Also, rinse the fins at the back side of the unit as well. Dirty units can cause this to happen. If you clean it and it continues, you have developed a refrigerant leak. Since window units are so inexpensive today, it is not cost effective to hire someone to come out and find and repair it. Hope this is of help to you.
Apr 11, 2009 | Frigidaire FAC052K7 Air Conditioner
Kia Rio 2002 turns over but does not fire
This may be the fuel pump failing, if it is it will strand you some time in the next few months.
Oct 05, 2008 | 2002 Kia Rio
My Rio MP3 player will not stay on... everytime i try to turn it on, it will turn off then (without me doing it) start up again, turn off, and repeat that same ritual again and again. I have tried to fix...
1.Connect to the computer and backup whatever music you have. 2.Go to my computer and figure out which drive your Rio is. Click on the drive. 3. Now you should see an Internal Drive icon. Right click and press format. 4. Now it should work fine, reload the music and enjoy.
Aug 12, 2006 | Rio Carbon MP3 Player
Coffee Makers & Espresso Machines Logo
144 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
