Question about GPX D1816 DVD Player
Can't get it hooked up to convertor box.
Lost instuctions. Can't get my DVD player hooked to convertor box. My TV is analog.
  • May 11, 2010
    What type connection are you coming from and what type are you trying to got to?
    Scholar:
  • 145 Answers
I need illustrated directions on how to hook up a vcr, dvd and converter box to a tv
vcr to video 1 on tv
dvd to video 2 on tv
convertor box- to video 3 on tv- unless you have composite and or hdmi then you need to verify that these are also available on your tv, if you do? use either one
Mar 05, 2010 | Insignia Digital-to-Analog Converter for...
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Jul 21, 2009 | Toshiba SD-V392 DVD Player/VCR
Converter box
3/23/09 --- I don't understand why you would hook your converter box or antenna to your DVD Player. Converter box is only functional between an antenna and a vcr (and/or a TV). DVD Player hooks directly to TV (NOT thru a vcr, coding on dvd discs will screww up the signal and make it fade!) Good luck.
Mar 20, 2009 | Insignia Digital-to-Analog Converter for...
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Dvdrecorder and convertor box
If the clarification request is correct. The only thing i can suggest is. Plug aerial into converter box. plug converter box into TV using either scart or coaxial cable. then connect converter box to dvd recorder using scart or coaxial cable depending on what you used to plug converter box into TV with. Then plug dvd recorder into TV. I don't know if you have to set-up the converter box to start receiving i'm not sure. But try this anyway.
You'd probably have been better off getting a free-view box and your dvd recorder. Because as long as you've got a free-view box you'll always get digital. Hope this helps
Jul 29, 2008 | Televison & Video
Converter box
the digital box has to hooked up the rca plugs on the bac of the vcr if you want to use the vcr (you will only be able to pick up channels throught input and the box will have be set on the channel you want to record. You need a switch to hook the vcr and dvd player both up. the atenna cord can be attached to the back of the convertor box then attached to the tv.
Jun 15, 2008 | Insignia Digital-to-Analog Converter for...
GPX D1816 DVD Player Logo
146 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
