Question about Goodman CKL24AR24 Air Conditioner
My air conditioner fan is broken, i think.
My fan on the outside unit is not spinning as fast as it should WHEN it decides it wants to turn on after a long humming sound
  • honeymokey
    honeymokey May 11, 2010
    Must be time for a new fan motor. See your local appliance parts store for one.
    President:
  • 3,433 Answers
Fan may need a new start capacitor. It appears or sounds like the motor is not getting the puwe it needs I don'y know what "not fast enough" is to youm but those fans really dont turn very fast, There should be two fuses in a box near the outside unit/ One can bbe bad causing low power to unit. To ck the, There should be something on the fuaw to indicate it's blown. WARNING!! dO NOT TRY REMOVING WITHOUT TURNING OFF ALL POWER AT THE MAIN HOUSE SUPPLY CIRCUIT BREAKER, hIGH VOLTAGE CAN AND WILL, GIVEN THE CHANCE. iF IN DOUBT, CLL OUT A QUALIFIED SERVICE COMPANY.
Posted on May 25, 2009
My outside amana prestige ac unit ( rcb30c2a) gets very hot when it is turned on, but the fan does not turn.
Hello, try spinning the outside fan with a stick or a small object you can spin the fsn blades with, if this gets the motor running the capacitor must be replaced. If the motor does not start by manually pushing it the motor will have to be replaced.
Jun 30, 2012 | Amana Heating & Cooling
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
so the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Nov 10, 2010 | LG Heat cool Window Air Conditioner
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
Fan Won't Spin
Is it humming like a stuck motor or rattling, like a loose fan. If it's rattling, the fan could eith be loose on the motor or, the center hub could have broken loose.
Aug 10, 2009 | Carrier 38CKC036 Air Conditioner
Outside A/C unit
you should be able to hear the compressor motor running. if you dont hear anything its more than likely ists a control problem. is the fan running inside?
Mar 15, 2009 | Ruud Handle Air Conditioner
Outside fan will not turn on
If you can spin the fan blade with a screwdriver or something and get it to take off you probably have a bad capacitor. If it will not turn then you probably have a bad motor.
Apr 02, 2008 | Goodman CKL24AR24 Air Conditioner
Goodman CKL24AR24 Air Conditioner Logo
709 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
