Question about Toshiba 42HP66 42 in. LCD Television
Using 42HP66 as a Computer Monitor for a Compaq Presario 2150NX Desktop
I can't seem to get my 42HP66 to work properly with my desktop computer. I can run it in Safe Mode w/ networking but can't run it in Normal Mode....I keep getting a NO SYNC SIGNAL messege. Also when i run it in safe mode i get 3 blurry spots on the screen, one in the center of the screen stretching the width of the screen and 2 more on the top as well as the bottom. Anyone have a solution?
  • Joshua Gary
    Joshua Gary Nov 02, 2013
    I'm having the same problem running my Compaq Presario CQ62 on my Insignia NS-LCD22-09. It will run in safe mode, but not normally. I get a Mode Note Supported message if I try to run it in normal mode. I tried looking for a Start in VGA mode option, but to no avail. If you have any suggestions for my particular problem I'm listening. Thanks
  • 50 Answers
Reboot your PC! When the pc starts booting up push F8 it will take you to the same screen asking you if you want to run the pc in safe mode! What you want to do is to select the Start PC in VGA mode! It should set your video card to a default setting allowing it to work with the TV!
I hope this helps you!
Please feel free to call or message me if you need more help!
Posted on Aug 26, 2009
My computer has recently decided to stop working. I can turn on the tower and the monitor to power it up and the tower does it's normal thing like it is working, the screen on the other hand stays...
If you mean you didn't get any display in your monitor the first solution is u must reinsert your memory and memory slot.if still have the same issue confirm your monitor is connected to your tower properly.if you still have the same issue just replace your memory (ram).thank you.
Sep 05, 2011 | Compaq Presario 5000 PC Desktop
My compaq 1725 computer moniter won't turn on when I press the power button. The actual desktop is on and seems fine but the monitor remains dark without even giving the orange light that it used to.
first check the power cable if its properly plugin, and check if ac to dc adaptor has a output power.
you can check it by using digital voltmeter or an analog multimeter, you can see the pin output in the back of the adaptor, it has positive and negative sign.
Aug 14, 2011 | Compaq Presario 1725 Monitor
Compaq Monitor WF 1907 immediately after the Desktop /Monitor (set at VGA) is turned-on gets stuck at the COMPAQ sign in the center and F10=SetUP, EXC=Boot Boot Menuplus F11=System Recovery all displayed...
Try using your windows cd to boot up the computer and if that does not work then you may need to reset the bios. Inside the case if it is desktop there is a way to reset the the bios. There is a jumper that needs to be switch then switched back that will reset the bios. If this does not work may need to get a new hard drive. The MBR ( Master Boot Record) may have been corrupted.
Mar 26, 2011 | Compaq Presario SR5712F PC Desktop
Powers up screen is black, will work on external moniter
atomikhound, May need to find correct drivers for this unit. Try search at HP website using the unit's product number on rear of the monitor. What is date of manufacture on this unit? It seems that this monitor only works with a Presario 4800 series desktop computer for which it was custom designed for. The article I read at "" said it should be used as a boat anchor if you can't get a copy of original 48xx system restore disks that have the special "drivers" needed for it. Good luck. 12fixlouie
Apr 26, 2010 | Compaq Presario FX700 17" CRT Monitor
Trying to hook up compaq presario 5000 desktop, monitor is not working correctly, it works with the old Gateway computer, so I know the monitor and cable are good
check to see if you have two ports in the back of your desktop, try the other one if you do. If not, there is most likely a loose connection.
Mar 18, 2010 | Compaq Presario 5000 PC Desktop
Sr1720nx compaq presario no signal to monitor
Try changing the VGA cable or the other cable you are using.......
If that does not resolve your problem and that the monitor is good it means that your desktop's graphic card is damaged.....
Try replacing the graphic card or if it is an internal one..... add one in your agp or pcie slot
Regards :)
Jan 21, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
Toshiba 42HP66 42 in. LCD Television Logo
303 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
