Question about Kodak EASYSHARE M1063 Digital Camera
Kodak M1063 Camera will not stay on.
Even after fully charging the camera, when the power button is pressed it turns on and immediatly turns off. I have had it for 3 months.
  • Anonymous May 26, 2009
    Kodak Easyshare V1253, when I press the power button it lights up, but then immediately shuts off.
Try holding the power for about 5 seconds before releasing your finger. That is what I have to do with mine.
Posted on Jun 02, 2009
  • 477 Answers
You are getting a lens error it is not fully booting up causing your issue.
Posted on May 25, 2009
My Kodak M1063 digital camera will not turn on no power at all
Kodak EASYSHARE M1063 Digital Camera My Kodak M1063 digital camera will... Answer my camera will not turn on no power at all.
Feb 13, 2010 | Kodak EASYSHARE M1063 Digital Camera
My camera wont turn on and lens stays out
are you using the battery that came from the box KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001
first charged the battery for 4hrs and make sure when you charge it theres a light indicator in the camera., you may also try to turn On the camera while its charging in a AC adaptor., If its did the same thing call kodak toll free 1 800 235 6325. it means the camera gear lens is already defective thats why your camera will not stay On
Oct 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have basically the same problem. I sent it in for repairs. It came back and I followed the instructions they came be. BUT IT STILL WONT WORK. it's worse then before, the logo wont even come anymore ! :(
Jul 18, 2009 | Kodak EASYSHARE M1063 Digital Camera
My kodak camera v530 when i press power will display but will turn off immediatly.
This problem is frequently due to either weak/worn out batteries or corroded battery terminals inside the camera. If replacing or charging the batteries doesn't clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 14, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Kodak easy share M1063 digital camera wont stay on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera immediatly shuts off and lense goes back in.
Sounds to me that ist is more of a charger issue. Try to borrow another charger and see if that works or not.
Jun 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera Won't Stay On.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes....
thank u
rate me
Jun 01, 2009 | Kodak EASYSHARE M1063 Digital Camera
Won't turn on
Keep holding the power up button on untill it oppens up the lens I mean and light up the disoplay.
I hope you did not dropped it to a hard surface.
Vitally
May 28, 2009 | Kodak EASYSHARE M1063 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Won't turn on after charging; lens just sticks out
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
506 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
