Question about Intel D102GGC2 Motherboard
High pitched sound from VGA
High pitched sound like whistel like when ther are alot of frames in the game the sound is sharp and clear and less frame the sound becomes like a snake sssssssssss.
  • Intel Master
  • 4,806 Answers
Hi there.
If this the on-board VGA that's making the sound then remove the power cord from the back of the tower, remove the side panel and inspect the motherboard for swollen and leaking capacitors, they will look something similar to this >>>>>>
If you find one or more of these capacitors you can replace them by soldering capacitors of the same voltage and ohms but usually people end up purchasing a new motherboard.
Good luck and thanks for using FixYa!!
Posted on May 25, 2009
How do i know if the sway bar on my 1990 19e mercedes needs to be replaced
If its a sharp,quick rapping noise and you hear it going up driveways and hitting reflectors on the road I'd say end link bushing or frame mount bushings which wear out due to oil contamination usually.Also check for loose license frame or ratting pieces up front.less likely but also check suspension bushings for wear.Oil deterioration is a big concern with a high mile Mercedes with prolong leaking
Apr 17, 2012 | Mercedes-Benz Mercedes Benz 190e 2.6...
How do i stop the cam from making me look slow when i video cam on msn messager
this problem can be caused by:
  1. your web cam being unable to cope with a high frame rate ( this is unlikely)
  2. your internet connection speed is low
  3. your computer is running to slow to prosses the web cam information
Solutions
  1. if your webcam cant handle high frame rates, then the only solution is to buy a new, higher quality web cam
  2. if your connection speed is low, then close down other programs that use the internet, eg internet explorer or multiplayer games
  3. if your computer is running to slow to prosses the information, then close down any unnessesery programs, for example games, internet, or even word and exell
good luck, please take the time to rate this solution
thanks
Jul 16, 2009 | Radio Shack VGA PC Camera Webcam
New xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
Jun 16, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Test
Ballast Lamp provide back light in DLP TV and if its bad / broken TV wont power up. If lamp is weak, dark or less bright picture will come in screen. Color wheel is responsible for colors in picture and if its broke, TV wont power up and common problem with color wheel is high pitch noise while it spins.
Jun 12, 2009 | Sharp 65DR650 65" Rear Projection...
Clothes get caught between frame and drum
Is this the dcvh515 GE? Mine began doing that and then started making a high pitched scraping noise that sounds like it's coming fron the door gasket/seal.
Dec 21, 2008 | Dryers
High pitch sound
This is the electronics whisteling. This is 'normal' on all electronically controlled machines. On some, it is louder than on others - even of the same model. As long as it continues to function properly, I wouldn't worry about it. If it's about to go out of warranty, you might try and see if the manufacturer will cover the replacement cost. But it's definitely not worth paying $300 to eliminate the whistle.
Mar 12, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
No copies
You may have a bad drum ground or a bad charge cnnection.Try cleaning all contacts on the units and where they connect on the rear of the frame.
Oct 17, 2007 | Sharp AL 1631 Copier
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
Continous burst mode
The Movie Mode takes very low resolution frames and can be re-played frame-by-frame.
Use the Continuous Mode for resolutions 2,048x1,536 or 1,600x1,200 or 640x480 get more details than movie.
For higher frame rates, use 1,600x1,200 and you can get quite good photos.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Intel D102GGC2 Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
