Question about RCA R52WH73 Projection Television
Circuit board needs replaced
I found out the problem i just need help identifying the circuit board or mother board whichever it's calle din tv's. I have a 52" Rca projection i took the back panel off and looked at the first circuit board on the left when looking at it from behind. It is burnt looking for information to replace it not shure what to look for. any help would be appreciated.
    Problem Solver:
  • 9 Answers
I replaced mine, it's called the Deflector board. Some people call it the flyback board after the flyback transformer that is located on it. I found one on Ebay for 25 bucks a while back, so good luck. Troll ebay or find someone that is giving their tv away on craigslist because the convergence or a bulb is bad. Don't base it just on your specific model of TV though because many of them share this common board.
Try part #271827. That was the part number of the board I won on Ebay.
Posted on Jun 03, 2009
Vizio LC470DUG powers on for 4 seconds than goes off--possible mother board
No such thing as a mother board in a TV set. Here is a list of the PCBs
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it may be time to start testing different boards to see if they are functioning properly.
Main Board
The main board, or motherboard, is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. This part is also sometimes called the main module or the A/V (audiovisual) board.
Power Supply Board
Another large and important board inside a television is the power supply board. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long, thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T-CON board, is typically only found on LCD and LED TVs. Plasma TVs, on the other hand, use a logic board. The functions of the logic and T-CON board are similar: each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixilation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and Y-sustain boards only appear in plasma screen TVs. The X-sustain board may also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The X-sustain board activates all the display lines at once, while the Y-sustain board addresses all the individual lines of display. When one board breaks down, it probably does not affect the functionality of the other. However, it may be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short lifespan anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
Buffer boards are also only found in plasma screen TVs. Connected to the Y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
Dec 03, 2016 | Vizio Televison & Video
Need to get the circuit diagram for board e106527 srf-c 94v found on TV Digistar Model CR_20SS01D
quick way with location number for the part (a cap?) will be marked on the board---call the maker or Google the model number with the location number.
Oct 15, 2012 | Prima Televison & Video
Tv clixs on and off
check the capacitors and replace the power components.. if not handy with soldering electronics call Tv repairman as you may need to replace capacitors and possibly mother board .. Tv repairman may charge 75-150 dollars depending on cost of Mother board .. good luck
Sep 21, 2012 | Sanyo 42 in. LCD TV
Tv fell off the stand onto a carpet floor now wont turn on
Possible that the fall has damaged the mother board and so there can be CRACK ON THE MOTHER BOARD. So you need to remove power cord and check using a good inspection lamp on the board for broken circuit board. Use a good soldering iron with wire strips to join - take care not to short circuits as each line must be tested for short and continuity.
Jul 27, 2011 | Philips 32PFL3505D 32 in LCD TV
Motherboard is fried, what can i do?
Try website like Tvrepairworld.com,Ebay.com to buy a refurbish mother board,they might have it.Don't it time to buy and replaced for a LCD tv better tv over all as a tv and for buying for replacement parts later for replacement for tv needed parts later on as LCD tv needed circuit board for parts.
Dec 13, 2010 | JVC AV-56P575 56" Rear Projection...
Fried mother board
Hi!!
Click on the following link to identify your circuit board and order it. Price runs about $95.
http://www.repairclinic.com/Circuit-Board-Or-Timer-Parts?s=t-PLES399EC-%3d%3dc13e
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 03, 2010 | Frigidaire PLES399EC Electric Kitchen...
LG TV keeps flashing This function is not available now.
unplug the TV. hold down the power button for 30 seconds. plug the TV in.
this worked for me :)
Apr 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
Jan 19, 2010 | Philips Televison & Video
RCA R52WH73 Projection Television Logo
137 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
