Question about E-Machines eMachines Desktop PC
5260 I have had this pc for 2 years now and all was fine . just recently when i press the start up button the fan starts and it sounds like the hard drive is spinning but it does not start up straight away as it used to. If i hold it in sometimes for up to 4 or 5 mins eventually it kicks into life. Any help would be most appriciated. Many Thanks.
    Scholar:
  • 155 Answers
It sound like your hard drive has lost something or is ready to die. I strongly recommend that you immediately make a back up of all you important files, then even better an image of your hard drive. To do an image you can use something like Drive Image or Ghost; in this way in case you need to replace your hard drive it will not take 2 days to reinstall Windows and all the programs.
To better understand if your Hard drive isd daying, you can look at LED in the front of your PC to see if stays only for a long time. I also suggest you to use a nice and free utility Drive Fitness. You can download it from here http://www.softsea.com/review/IBM-Hitachi-Drive-Fitness-Test.html when you install it it will create a Floppy disk.
After creating your Floppy you start your PC from Floppy and it will test all the parameters of your Hard Disk.
If Drive Fitness doesn't find any issue means that there is a problem with Windows (Some file corrupted or lost)
Posted on Oct 21, 2007
M1160n wont boot windows xp nor two internal fans
Step 1:
Lets try this...
Unplug the cpu
Step 2:
remove the battery from on the mainboard
Step 3:
press and hold the power button for 30 seconds
Step 4:
release it
Step 5:
put the battery back in, plug in and turn on , it should work fine..
Step 6:
If that fails replace the power supply..
Dec 28, 2012 | HP Media Center m1080n (PC099A#ABA) PC...
I have a washing machine westpoint wmc 5260.E. power is on but it does not start when i press start
Regarding Westpoint WMC - 5260 , please share with me the washing instructions.
Appreciate your support.
Thanks,
Kavi
Mar 23, 2012 | Washing Machines
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
A 100 Toshiba won't start
the motherboard is prolly cracked, i hope the laptop is still under warranty, cause you will need toshiba to service it at this point. the problem is unrelated to the reinstallation of windows.
Mar 06, 2009 | Toshiba Satellite A100-S8111TD Notebook
My E machines 5260 won't start up! It appears to
Techguru2009: You might have a static electricity charge on your motherboard. First you need to ground yourself before you open the case. Remove the memory cards from the motherboard. Turn your computer on without the memory installed, you should hear several beeps. The system is letting you know that you have no memory. Turn computer off reinstall the memory cards, close case and boot up. You might also want to reset the bios while you are at it, you can do this by removing the cmos battery for ten minutes. Warning: do not open the case while the plug is still on. Safety first. I hope this helps.
Feb 26, 2009 | E-Machines eMachines Desktop PC
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
JBL on rour stop working one hour later every time
Hi, I got my on tour a couple of months ago and it worked fine. But just recently it starts stopping emitting any sound one hour or so after I start it. No sound at all, and the light goes off too. If I press one of the buttons, the light will glim just once.
Aug 01, 2008 | JBL (JBLONTOUR) Computer Speakers
Re: emachines model 5260
go to te control panel and click add hardware try reinstalling it!
Dec 09, 2007 | E-Machines eMachines Desktop PC
Emachine 5260
Bad power supply will do this
Oct 20, 2007 | E-Machines eMachines Desktop PC
Belkin Router - Network works for 5 minutes than everything loses internet capability.
hi,
           This issue usally occurs when the router is able to save the data stored or in  other words the Router id not able to AUTHENTICATE,  but as you already got a new router and you have already done the fireware upgradation of the router. we can also upgrade the firmware of your speedstream modem.
plz do these following steps ,( plz disconect the router from the computer and modem completly while doing the steps )
The Efficient 5260 modems that can be upgraded are as follows:
Look on the label on the bottom of your modem. It should read:
SpeedStream 5260 Ethernet ADSL Modem
Part Number: 060-5660-00x (where x=any number)
Revision: any (all revisions seem to work)
If your part number reads anything else, your modem is most likely not upgradable.
For those curious, 5660 models 003 and earlier do NOT support G.Lite ADSL, only DMT. If you are buying a 5260 or 5660 model secondhand, and your DSL ISP uses G.Lite DSL, it would be a good idea to check with the person selling you the DSL modem.
UPDATE: As of 5660 Firmware v2.3.0(2) and later all 5660 including 5260/5660 hybrids support G.Lite ADSL. It pays to use the latest Firmware.
PLZ REPLY IF THIS HELPS, I WILL TRY TO FIND OUT THE RESOLUTION FOR THIS ISSUE
REGARDS.
Gunjan ';';';';';';';
Oct 18, 2007 | Belkin (F5D8231-4) Wireless Router...
E-Machines eMachines Desktop PC Logo
50 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
