Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Printer problem The HP C14180 All IN ONE Printer printer prints only half page and then it chooses to stop.
Sorry - you are much to slow on the trigger - got it fixed myself - and I am not a techie,, by any means!! So much for Mr Fix-it!
Posted on May 28, 2009
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
HP 1160 e cuts off side of page. How do I fix this?
Printing or paper?.. If printing check 1. check with another cartridge 2. check half test page(half test page while printing half page stop printer remove cartridge & paper see the image created on cartridge drum or not ,if not clean the Laser scanner assm, check on paper proper image or not if not clean the transfer roller.(looked like sponge roller located just under the cartridge location). beyond this trouble shoot, advised to send it to service center..
Sep 13, 2011 | HP LaserJet 1160 Printer
Printer has started spitting out one clean page for every page that is being printed. That is, if I have a two-page document to be printed, it spits out four pages, two pages without anything on them, and...
Go to START, Printer & Faxes, right click your printer and select properties. Under the advanced tab, click seperator page, delete whatever is in the box and click OK. This should stop the blank pages from printing.
Hope this helps
-samson39
Jul 26, 2009 | HP Photosmart C7280 Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
Printing on half-sheets
adjust your image to landsape and choose the paper orientation as portrait in printer properties and also choose fit to a page.
Oct 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
Print Quality
  1. In Windows, click on the Start button and choose Control Panel.
  2. Choose Printers and Other Hardware from the menu that opens.
  3. Choose View Installed Printers or Fax Printers.
  4. On the window that opens, look for your printer's name. Right click on the printer's icon and choose Printing Preferences.
  5. On the Print Quality tab, choose Draft or Fast (varies depending on the printer).
  6. If you want to conserve your color ink, choose Grayscale Printing on the same tab (just remember you'll have to uncheck that box if you want to print something in color).
  7. Press OK. That's it; now your printer will automatically print in Draft Mode (and in grayscale, if you chose that option) until you change it back. To change it, simply follow the same instructions and choose Standard for print quality
Jul 22, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printer only prints half a page
I have a Lexmark 5400 series printer that is only printing the top half of a page. Any suggestions anyone ?.
Jan 20, 2008 | Dell A920 InkJet Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
218 people viewed this question
Seeker5211
Seeker5211
