Microwave quit completely. It is aGE Spacemaker XL1800. Checked breaker, and breaker is on.
SOURCE: GE Profile Spacemaker® XL1800 Microwave Oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: My ge profile spacemaker xl1800 turntable stopped .
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
SOURCE: ge spacemaker microwave
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
