Question about Rio Go Video DDV9475 Dual Deck VCR
LXI VHS - No Video on TV
I have an older LXI VHS machine. I'm using a three connector cable, video out, audio LR, yellow, red and white. The cable is connected from the VHS to a box that has cable in and cable out to TV. All units are set for channel 4. The VHS plays, stops, FF, Rev and all functions seem to work along with indicator lights on the VHS box. The remote appears to working too, just no picture on TV.
Thanks,
Carol
    President:
  • 2,992 Answers
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
Posted on May 26, 2009
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
I would like to know how to conect a Sony VHS to a TV? What leads go where etc. Thank you for your help.
hi,
you can connect the audio video out of your VHS to the audio video input of your tv. for that you need an audio video cable (have three RCA pin at the both side, one for video(yellow) and the other two (red and white) for audio.
connect the one end of the three rca cable to the VHS's audio video out according to the color code. and the other end to the tv's audio video input.
Then select the corresponding AV input in your tv using the remote.
ok
Jan 25, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
How to connect to an analog tv
Try to locate the composite video/audio in(1) and audio (2) out sockets of your tv.
(1): three small round sockets, one yellow, one white, one red (2): two small round sockets, red and white. (only if you want sound from your tv on your marantz receiver)
You will need a composite audio/video cable: 51433a4.jpg
and a composite audio cable: db5db51.jpg
Connect the composite video/audio cable (1):
the yellow lead to MULTI OUT (yellow) the white lead to MULTI OUT (white) the red lead to MULTI OUT (red)
on your tv: connect these cables to the respective yellow, red and white input. (there should be a text like: game in/dvd in/ext in/AV-1/VCR) If all you see at the back is a big socket like this one: 0f41fcb.jpg
you will need a SCART-to-composite adapter, like this:
(2) To get audio from your tv to your Marantz, locate an 'audio out' (red + white round connectors) on your tv, and connect these pins using cable (2) to TV (complete bottom left on your Marantz).
Dec 13, 2009 | Marantz SR7002 6.1 Channels Receiver
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
No colour when watching dvds ok for everything elese
You will have to make sure you are connecting them with the red and white cables on audio and the yellow on video at both ends, as both your dvd and tv have low def and hi def cabling options.
That means Red and White to Audio at each end and Yellow to video at both ends. If you connect the yellow cable to one of the other three connectors at iether end you will only get black and white as they are meant for a different type of connection.
To get the maximum quality out of your sets you may want to purchase a set of Hi-Definition Component cables which will give you a set of five cables, still red and white for audio but now red, green, blue for video.
Hope this heps a bit more,
Chris
Apr 30, 2009 | Panasonic DMR-ES35VS
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
We have an Akai flat screen tv and a phillips dvd player it is all connected but we have no sound what could our problem be I tried checking all the cords and adjusting the tv settings.
This is going out on a limb, but are you using an s-video or component connection and forgetting to also use sound cables?
Older style A/V cables have a yellow connector for video and red and white connectors for sound. Superior s-video and component connections (which if you aren't using, you really really should) are for video only, and require also using red and white audio cables. S-video is a big connector that looks like the kind used on a computer mouse or keyboard, and component uses three cables, red, green, and blue connectors.
Mar 25, 2008 | Televison & Video
RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 23, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Rio Go Video DDV9475 Dual Deck VCR Logo
239 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
SHARCNET-USA
SHARCNET-USA
Jaime Hernandez
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
