Question about Whirlpool Refrigerator Inverter Box - 8201670
Water drips into refregerator (not the freezer portion)
I have model # 106.67181791
How do I get to the drain tube to see if its blocked?
  • 104 Answers
We have just had our seals replaced and the tech guy that did it also blew the drainage pipes out with compressed air [ a mini air compressor would work ] and now our fridge doesnt leak and gets really cold , the drainage pipe on our westinghouse was at the rear inside near the light
Posted on May 26, 2009
Model 795.71013.010 drip pan is full and leaking onto floor
Those models have problems with the defrost drain and defrost drain tube becoming blocked. Have you noticed water buildup on the floor of the freezer? See item 105A that is the drain tube.
http://c.searspartsdirect.com/lis_png/PLDM/F1002002-00002.png
That drain may have come unblocked because the refrigerator was off long enough for this ice to completely melt overflowing the ice trough seen in the video.
Appliance 911 Sea Breeze
Sep 13, 2015 | Kenmore Refrigerators
Need a diagram of Amana top freezer refrigerator model #ATB2132ARW My fridge has a clogged drain tube, but I can't locate the drain.
I can't find a diagram but have a different model Amana. The drain tube on mine was located just above the drip pan under the refrigerator. It was a soft plastic/rubber and had become clogged due to something sticky that stuck it together. Caused the freezer water to back up and after cleaning the tube, I had to defrost the refrigerator completely to melt the ice blocking the tube at th top (in the freezer). Sorry I can't help with more info.
Jul 30, 2011 | Amana ATB2132AR Top Freezer Refrigerator
Water is dripping down the back wall of my hotpoint refrigerator model # CTX21DA. The water collect at the bottom and drips onto the floor. How old is the refrigerator and what would the cause be for...
The problem is relatively simple to repair. The drain tube in the freezer is blocked so the water will drain down the back of your fridge. Often the drain gets blocked by ice build up. The defrost circuit in your fridge has failed and ice is building up on the evap coil in the freezer. When the ice builds up, it blocks the drain tube. The typical failures of the defrost is the timer failing to advance or the heater is burned out. Being that said it was probally manufactured at least10 years ago, and certainly a new refridgerator would be more energy efficient and cheaper to operate than using a 10 year old model. Whether you should repair or replace it depends on whether you have the money to replace it. Hope this helps you.
Dec 06, 2010 | Hotpoint Refrigerators
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Water leaking into refrigerator
There are 2 types - the older types where you have a drip cup in your refrigerator extending to the back of your fridge into the wall and down the hose - OR the newer ones where the drain is in the freezer and goes straight down the drip pan. Look at the back of your refrigerator, if you see a tube extending down into a drip pan (on the compressor or next to it) that is your drain tube, if you can locate a drain cup in your refrigerator you can remove it and dislodge anything plugging your drain tube.
For newer or models without a drain cup, you'll have to remove the freezer panel and look at the bottom you should notice a hole, this is where the melted ice from defrost drips into through the tube and onto the drip pan below. Maybe there is excess freezeup ordebris or something blocking out the drain, so the water will spill over to the other opening where cool air passes onto your refrigerator - usually the culprit is excess ice buildup - if it is the case you can manually blow dry that section, clearing up the hole. once done you might also want to insert a piece of wire or long flexible cable to unplug the drain line.
Good luck.
Sep 15, 2009 | Kenmore 60721 Refrigerator
Water dripping within the fridge
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 18, 2009 | Refrigerators
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Water dripping into refrigerator someone told me that the drain in the back of the freezer could be blocked, its a self free defrost freezer. cant find drain tube to check.
remove rear panel inside freezer and you will find drain pan at bottom with drain in the middle. probably blocked with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 14, 2008 | Amana Refrigerators
Whirlpool Refrigerator Inverter Box - 8201670 Logo
253 people viewed this question
Top Whirlpool Electronics - Others Experts
Are you a Whirlpool Electronics - Other Expert? Answer questions, earn points and help others
