Question about Ulead Videostudio 8 for PC
Very poor connection
The video is green and violet. there is poor connectoin. the sound iis not clear at all and laggy. i have top of the line cables and connectors what do i do?
  • 822 Answers
Your problem is in your cables connectors.
Posted on May 25, 2009
Can i make my videos less laggy
everything you connect to the net, needs to ret the data through one cable. If your connection is slow, you can't change anything. Special not when you try to do more than one thing at the time. Or if someone else in the house is using the same internet connection. Some connections can't made to go faster, because the cable can't carry more. Be aware if you want another provider, they offer up to ??? Mbit /s but never give you the max.
Nov 21, 2014 | Microsoft Windows Vista Home Premium with...
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
GE Double Oven Controller WB27T10276 Connection Details
I successfully replaced my WB27T10063 with the WB27T10276 (ERC3-GE-M) by following the instructions (Pub. No. 31-10515).
"they tell you for the Broil Relay to connect L1A to the common terminal."
This is simply a misreading of the poorly written instructions.
  1. Bake: yellow goes to yellow NO.
  2. Broil: violet goes to violet NO.
  3. Broil: black L1B goes to violet COM.
  4. AUX 2 goes to AUX2 (black and white wire).
  5. AUX1 goes to AUX1 (daisy-chained black from violet COM/L1B).
  6. OV2 goes to OV2 (white wire).
  7. OV1 goes to OV1 (brown wire).
  8. L1A goes to L1A (daisy-chained black from AUX1).
  9. N goes to N (daisy-chained white from OV2).
  10. GND needs to be "tucked under the (steel) clock bracket" on the control panel.
The hardest part was disconnecting the wires from the old ERC. Took a LOT of force! I also had a hard time figuring out how to release the green tape thing apparently labeled "J1" on the old ERC. Piece of cake after that.
Aug 09, 2012 | GE JKP27 Electric Double Oven
My tv lost picture and show only green screen although sound works
Hi, what you have is called hte "default " screen, the audio connection is apperebtly fine since you have sound, so the question is why video stopped. More than likely the video connection came loose somewhere, iI suggest retracing the " video connection " from end to end. If you're using an hdmi cable that has both audio and video cables combined-so it would be the cable or the player or jack on the tv's side that was defectice. if using standard " RCA " cables, those are the colors yellow, for video and red & white for audio. If someone or something become tangled in rca cables this may sometimes stress a connection and give a green screen ( with yellow cable still connected it will feel slightly loose ) I hope this helps ,good luck Prodzilla
Apr 10, 2011 | Sharp Televison & Video
I LOST THE CONNECTIOS ON PIONNER DEH-2100 HOW I KNOW THE RIGHT CONNECTIONS
Red - Power - Connect to Acc on ignition or battery positive. Connected to Battery the unit will not power down when the ignition is switched off
Yellow - Memory back-up. Connect to battery positive
Black - Connect to vehicle earth or battery negative
Blue/white - Used to power up remote power amplifier or power antenna. Do not draw more than 300mA at 12V from this line
White + White/black - Front left channel
Grey + Grey/Black - Front right channel
Green + Green/black - Rear left channel
Violet + Violet/Black - Rear right channel
Use the wire with the black line in it for negative on any channel.
Do not earth any speaker wires.
RCA output jacks are used to send the output from the unit to an amplifier if you have one and cannot be used to power a speaker.
Dec 29, 2010 | Pioneer DEH-2100 CD Player
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
After having my dish network upgraded to HD and installed, i notice on my tv now that the green and red colors are not there, predominant on channels like ESPN that use these colors most. I._E.: football...
Sounds like one of the cables got plugged in wrong.
Look at the back of the HD box and there should be a cable with 5 ends on it (Green,Blue,Red, White and Red).
Often times a flashlight can help make sure you see the colors clearly.
The Green,Blue and one of the Reds is for video. The White and other red are for Audio.
When you unplug the connector the connection it is attached to is also colored. Check to make sure the colors on the cord match the color they are connected to at the box.
The most common mistakes connecting these cables are:
1) Crossing the Green and the Blue cables.
2) Connecting the Red Audio cable to the Red Video connection.
If all of the connections match the correct colors find the same cable where it plugs into the back of the TV and check these connections that they are correct.
When you find and move the cable to the correct connection this should clear up your color and you can begin to enjoy your new toys....
Good Luck....
Jan 15, 2010 | Panasonic CT-34WX54 34" TV
BOSE 321 DVD movie movie picure is blue. Its connected to a Sony LCD digital Wide screen TV Bravia Model KDL 40V2500 and my cable box. Could it be a loose connection.
Sounds like you are using a component cable(red,green,blue) rather than an HDMI cable.
Component cables are fine to use but if one of the 3 cables is disconnected, loose or bad, you may see blue video.
Check for loose connections or bad cables and make sure the proper color is plugged into its matching color.
Oct 25, 2009 | Bose 3·2·1 II System
I have a Sanyo HD TV and my Playstation 2 has the red white and yellow jacks but when I plug them in I get no color. If I move them to the bottom red jack and the top green and blue jacks it works but...
the red and the white cables are the left and right sound
the yellow one is the only one sending a picture signal
plug it into the video in...which should be yellow on that tv, the green and blue jacks are for another type of video connection
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Help with install on clarion vrx935vd
The green would have to be connected to the handbrake indicator switch. Additionally, Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 13, 2008 | Clarion VRX935VD Car DVD Player
Ulead Videostudio 8 for PC Logo
Top Ulead Computers & Internet Experts
d3yavu3
 Grubhead
Grubhead
Sandrine Sims
Sandrine Sims
Level 1 Expert
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
