Question about Dryers
Dryer not working
I turn dryer on i can hear motor but it will not start tumbling then it shuts off
    President:
  • 1,185 Answers
Belt is snapped
Drum cant turn , machine gets hot because the drum provides the airflow , thermal overload kicks in machine shuts down.
Resets when it has cooled.
Get someone to take the back off or tip it backwards and see if there is a belt laying on the chassis or the floor
Posted on May 25, 2009
Maytag neptune dryer heats but wont tumble
When you spin it by hand, is there resistance? Can you hear the motor turning? In fact, when you switch it on and it starts to heat, can you hear the motor turning, or is it silent?
Sounds like the belt is broken, in which case there will be little resistance.
If there is resistance, it may be the motor or circuitry controlling the motor.
Aug 24, 2015 | Maytag Dryers
Dryer won't tumble.
check the belt............if ok then could be the motor ..........cheers
Apr 15, 2014 | Whirlpool WED9600T / WED9600TA / WED9600TW...
Frig. gas dryer agq6000es not tumbling
Do you hear the motor running? With door closed.
Most dryers will spin though a little hard to do so. If it spins VERY easy the belt is possibly broken.
If the dryer is several years old it Could be the belt.
Also check for a switch for the door, if there is one.
Door switch would shut off dryer when opened.
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Whirlpooldryer LEN2000PW1 when you shut the door turn the dial you hear a clicking sound and doesnt tumble. Belts not broke and you can turn motor manuelly.
This is a symptom of a blown thermal fuse located on the blower housing. It is wired in series with the motor and therefore cuts power to the motor when it blows and results in the motor not running. No dryer function works when the motor is not running. Remove the rear access panel and locate the thermal fuse. Replace it if found blown open including the cycling thermostat. Click on the link below for the detailed troubleshooting procedure.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers
Apr 04, 2011 | Dryers
Servis tumble dryer drum will not turn
If motor is sounding quieter than normal more than likely the belt has broken.
Jan 31, 2010 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Jun 30, 2009 | Kenmore 63942 Dryer
My hotpoint vtd20 tumble dryer will not start. I was using it then when I put a second load in and pressed start - nothing happened. The power light is on but no tumbling!
If you can hear the motor running but no tumble action then belt has come off.
Make sure the door is shut properly..
If it gets hot at the back, then you are difinately getting power to everything.
If you can hear a slight buzzing noise, then the motor is failing to start, probably due to a faulty start capacitor.
Dec 08, 2008 | Dryers
Dryer hums when turned on but won't tumble
SOUNDS TO ME AS IF THE MOTOR IS FRYED IT WILL START RUN FOR A WHILE THEN STOP ? I WOULD CHECK INTO CHANGING IT OUT OR A NEW MACHINE WHAT EVER IS EASIEST ON YOUR WALLET DURING THESE TIGHT TIMES GOOD LUCK
Nov 04, 2008 | Frigidaire FEQ332E Electric Dryer
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
