Question about Apple PowerBook G3 266Mhz w/ 14.1" Screen *WallStreet* PC Notebook
Running os10.3 need to connect a printer.does not have usb ports
I have an g3 wallstreet that is running OS 10.3.I need to know how to connect a printer being there or no usb ports.
  • 1,305 Answers
You can add a card that will fit in the slot in the side of your wallstreet. welovemacs.com has just the unit you need... Click here
then you can choose the printer via the chooser...
K
Posted on May 25, 2009
    Problem Solver:
  • 11 Answers
You could use a network printer. You counl share a printer on a nother computer and be connected to the inter via Ethernet or Wireless. Or you could go on ebay and buy an usb external card.
Reinstalling system software
Good question, the wall street is the same as the Pismo. A great and simple machine. I recommend using os x 10.4 as the highest level. You install the system disc in the optical drive and restart it from its pop up menu. then it will prompt you for each step. You can also hold down the option key on startup to select the disc to boot from.
There is a list of key commands on apple support. Easy way to do it is to just let the disk prompt you after it restarts.
Jun 10, 2014 | Apple PowerBook G3 Mac Notebook
As I can install a samsung ML1640 printer on a G3 iBook?
you have to go to the printer manufacturer to get drivers for the computer. The os comes with drivers for different printers but if your printer was manufactured after the OS you are using wa made it will not be inherent to it.
One thing to do is to connect the printer to the computer and reinstall the os with the system disk. Sometimes this will fix it. Another way to do this is to run software update from the apple drop down menu to see if there are any updates to your current os. That machine should run mac os x 10.4 if you have enough ram in it. Ram for that machine is very cheap.
May 03, 2014 | Apple iBook G3 Clamshell (M2453B) Mac...
Windows 7 64 bit OS does not see my G3 samsung external hard drive any more, it used to
The first thing to try is to move the USB cable to a different USB Port There are no drivers for this device so relocating the to a different USB port will most likly solve your problem
Sep 06, 2011 | Samsung G3 Station 1.5TB USB 2.0 External...
Trying to get an HP 1401 printer to work on an older imac G3 computer. Printer connects to USB port. Cannot find correct drivers qnd don't know how to install drivers on an apple imac.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11543&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=1103491&key=null&site=null
Nov 14, 2010 | Apple iMac G3 Desktop
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
I use a Mac G3 Wallstreet Powerbook with OSx. Does OSX talk SCSI?
It will only read devices connected unless there is a problem with the scsi port. Also be aware early scsi needed termination to be read.
Apr 08, 2010 | Apple Power Mac G3 Desktop
Will th 3210 printer work on a mac
Yes. From the HP 3210 product specifications:
Macintosh system requirements Component Macintosh Operating system OS X v OS 10.2.8 and up Processor G3 or greater RAM Mac OS X v OS 10.2.8 and up: 128 MB Free disk space 500 MB Video display 800 x 600, 16-bit or higher CD-ROM drive 4x Connectivity USB 2.0 full speed, front and back ports (Mac OS X v OS 10.2.8 and up)
GOOD LUCK
Feb 21, 2010 | HP Photosmart 3210 Printer
I have a Powerbook G3. Gets power but does not boot up.
It may not be a fan, it may be the cd drive spinning up. Is there a cd in it?
Jul 18, 2009 | Apple PowerBook G3 266Mhz w/ 14.1" Screen...
My notebook says not charging, it's brand new
there was an issue with the ibooks and older powerbooks (wallstreet) that the pmu would stop charging at about 10%. Apple released an app to fix it,but you must be running os 8/9 to use the app. the apple download and description can be found here: http://docs.info.apple.com/article.html?artnum=60655
Jan 17, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
PowerMac G3 connections and compatibility
You need a adapter from your serial port to usb/also yu need to update your os to 10.2 or 3
Dec 01, 2008 | Apple iMac G3 Desktop
Apple PowerBook G3 266Mhz w/ 14.1" Screen *WallStreet* PC Notebook Logo
83 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
