Question about Sony Dream System DAVDX155 Theater System
Only black and white picture on screen when showing DVD
Hi! how are you ? i have a problem hope u can help ? I were messing around with my sony dream system SW volume, then put in a DVD and it start to show Black and white. How can i get it back to color? thanks very much hope u can help.
  • 822 Answers
Its a PALSECAM mode. change mode to NTSC! that y black & white picture. click button PAL/NTSC.
Posted on May 25, 2009
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Sony KV-36XBR450 seems to turn on but screen slightly pops white around edges but immediately goes all black and will not show a picture.
According to the symptom the problem seems that the high voltage cap is loose and not plugged properly. For your convenience see the below pic and reset it. The number 11 is the target component in pic. Hope this will solve your problem.
Note: This component has a high voltage, please don't forget safety measures.
Thanks for using fixya.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
My dvd movies only plays in black and white.
are you using component video cables (red,green,blue) or composite (yellow,red,white)
most of the time if the blue or red cables from the component area seated firmly they cause the picture to be in black and white.
Oct 22, 2009 | Sony Dream System DAVDX155 Theater System
Black & White Picture in different input modes
Can you describe the connections please? I suspect that the DVD +/or WII is outputing component video and you have it connnected to composite video. Please diagram the conenctions.
Thanks,
Dan
Aug 21, 2009 | Televison & Video
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Screen does not show picture, distorted image
If you go to 1800customersupport.com it has some good info. Alco Electronics is the maker.
Oct 04, 2008 | TruTech PVS12701 Portable DVD Player
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Black and white picture
Have the RGB settings been messed with?
Jul 08, 2008 | Sony DVP-NS300 DVD Player
Picture Problems
check for poor grounding of the input signal cable wire.
easy way to check this is put in a dvd and is that in color?
Feb 01, 2008 | Sony KP-53XBR200 53" Rear Projection...
DVD has no color
Check your remote for a button that says, Progressive Scan, or PSCAN. Push it and then play your movie. Should work. Worked for ours. Good luck.
Sep 15, 2007 | Televison & Video
Sony Dream System DAVDX155 Theater System Logo
248 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
