My new LG cookie has no caller ID on my text messages or calls, even though the numbers are saved in my contacts.
SOURCE: my phone when someone calls wont show the name just "unknown call"
check your phonebook ,, it may have double entry...is it all who calls you display unknown calls?
SOURCE: Nokia 3120 Caller ID Display
Save your numbers along with country code. Like +8801719002255. Here +88 is country code and rest is mobile number. Your porblem will be solved.
SOURCE: i have no caller id on my text messages or incoming calls
This is normal. T-Mobile does this. Unless the person is in your contact list it only says the number. There is no solution, because that is not a problem. They did this on purpose, I do not know why. But this is how it is.
SOURCE: CECT KA08 Caller ID/Msg ID
Hello, I had the same problem, but i figured out how to get the callers
id/information. On the main page select Call Center>>Call
History>> SIM1(or whichever you are using)>> and select
either the Missed/Dialed/Received calls. Lets choose Dialed Calls for
now. Select a phone number that you recognize>>select
OK>>Options>>Save to Phonebook. In here you will create a
new contact. Make sure you delete this old contact information from
your phone book. (so you don't have doubles if already saved to your
contact list). Now you can go to your main menu again and select the
phone book option. Select the contact you have created and add a photo
and ring tone you like. Now when you get a call you get their photo and
rign tone. For sms you get only their name, but thats good enough for
me.
SOURCE: how can i block certain number from texting
This should be simple enough but this phone is **** and most things aren't staightforward with it,
This is what you have to do:
firstly, I know u prob dont want to do this but like I said, this phone is ****, save the number/s you want to block in your contacts, you must save them under a group, jus choose VIP , lol
Then, on the main screen on your phone, touch the blue icon on bottom right, go to settings, call settings, common setting (scroll down if u cant see it), then select call reject, touch the slider to "On", then touch reject list, then choose the group you want to reject, in this case VIP,
Now, any numbers you'v stored under VIP will not be able to call you or txt you, any probs, email is [email protected]
Fixed now, turns out it was an error that occurred when sending my contacts via Bluetooth from my T610.
