Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
No power to hot tub...
Electrical keeps tripping. we changed the braker box, changed fuses in the hot tub.....nothing...when we turn the switch back on in the braker box, we hear the hot tub click, but the power never turns on.
We have a QCA model # keywest purchased new in 2006. It started "tripping after 3/4 of a cycle....we have always kept the tub clean, but the water began to get a green hue to it, so we totally emptied it, started over, and it worked great for 2 weeks again, now it tripped and we can't get it back on. The tub is on its own breaker box.
  • jkzerr May 31, 2009
    Thanks for the information....we have an electrician coming out this week....hopefully, this time of year electricians are extremely busy-but will let you know what the outcome is........sure would like to have my hot tub back!
  • 247 Answers
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
Posted on May 25, 2009
    Problem Solver:
  • 8 Answers
If you don't have an ozonator on this spa, then it could be the heater. If you do have an ozonator, unplug it and see if the problem goes away. Moisture in the ozonator can cause short circuiting. Otherwise, heater element could indeed be culprit, or if the element touches the sidewall of the heater tube, that can also be a short.
Posted on Apr 10, 2010
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
After replacing my PC board in the hot tub it does not work
A couple of things could of happened here;
1. Most common issue I see is customers do not reset the brakers right. A GFCI braker, when tripped, must be switch all the way to the off position then back to on. When a GFCI braker is tripped it looks to already be in the off position.
2. Check your system fuse. You can check for continuity or if you check the voltage, putting a lead on each side of the fuse while it's installed, it should read 0 voltage if it is good. If it reads 120vt replace it. You can get them at home depot or lowes for less than $20.00
3. You shorted out the circuit board using a magnetic tip screw driver. It happens.
4. You bought a rebuild board from e-bay. In this case if the seller quits responding contact paypal.
Aug 11, 2013 | Pool & Spa
I have a Beachcomber Model 350 hot tub abd the GFCI is tripped and won't reset
You may have a bad heating element. But first make sure you have power to the gfci. (check the braker) You can test this by disconnecting the heater leads and see if it will reset. If it still trips try disconnecting your equipment one at a time, ie. blower, ozone, circ pump, booster pumps. If nothing solves the gfci issue you need to replace the gfci. All of this is assuming you have a blank gfci receptical monted to your spa pack.
If your talking about the 50 amp gfci at the braker box try pushing the braker all the way to the off position then back to the on possition. If it trips right away do the above.
Aug 06, 2013 | Pool & Spa
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
Electric shower is not getting hot
Locate your electrical panel box, find the breaker for the water heater, turn it off then back on, locate the water heater. Fins the powere disconect. Sometimes they are a simple pull disconect or switch, sometimes they are another breaker or fuse.
Check the fuses or flip the breaker if aplicable.
Do you have a volt/ohm meter?
Dec 06, 2008 | Home
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
1,121 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
