Question about Char-Broil Performance 463463006
Heats only to about 350 degrees
Grill does not heat above 350 degrees
    Problem Solver:
  • 8 Answers
How old is it may neet to clean and blow out burners
Posted on May 27, 2009
Won't heat up above 200 degrees.
Try turning off the valve to the tank, then leave the knobs on the grill open for 2-3 minutes. Turn off the grill knobs, slowly, slowly open the valve on the tank. Relight the grill and see if it gets hot.
Mar 26, 2014 | Broilmaster Premium P3 Grill
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
One day it will not heat up over 300 degrees and the next day it will heat up over 400 degrees without any problem. I dont know if it is the gas tank or the grill. Nothing on the grill appears to be...
More than likely, it's the OPD valve on the LP G tank. When it won't heat up above 300 degrees is after the tank was turned OFF & then turned back ON? If that is the case, disconnect the gas line from the tank, wait 5 minutes, reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY. This will keep the tank valve from locking up the grill regulator and thereby, gas will get fully to each burner. If this doen't correct the problem the first time, repeat the above procedure.
That should solve your problem
Mar 06, 2011 | Fiesta Blue Ember Gas Grill
I have a natural gas hookup and my grill takes a long time to heaat up (15 minutes) and max degrees is 350 - 375. I found dust in the connection hose blew ut out. Also took grill apart and cleaned...
Unfortunately, that's the way it does on Natural Gas, in an outdoor environment. The reason being, Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Of course, on the plus side, you don't have to get tanks refilled. With that said, the thermometer on the grill may be faulty.
To test this theory, buy an inexpensive oven thermometer (the kind that can be placed on an oven rack) and place inside the grill, when you're preheating it with the lid closed. Once you grill thermometer reaches 350 degrees, open the grill hood and compare it the two temperature readings. If the oven thermometer is reading significantly higher, then you no the grill thermometer is faulty.
Hope this helps you get back up to temperature.
Mar 02, 2011 | Weber SPIRIT E-210 (NG)
When the grill is on high heat for all 3 burners only heats up to
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Apr 05, 2010 | Weber Genesis Silver B Grill
Weber won't get very hot
Safety valve needs reset.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait several seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and the rep walked me through the reset. All grills made after 1996 have this bypass valve.
Jun 21, 2009 | Weber Genesis E-310 Gas Grill
Grill not getting hot, fire not around burners, knobs are so hot you can't touch them. not getting over 300 degrees, fire seems to be behind knobs
We assembled our new Genesis E-310 yesterday. Went together nicely, but won't heat above 350 or so. It should get to 500-550 degrees withing 10-15 mins. Any ideas of what could be wrong?
May 11, 2009 | Grilling
Char-Broil Performance 463463006 Logo
177 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
