Question about Acer Aspire One PC Notebook
Upgrading to a 500GB hard drive.
Okay, I want to install a WD 500GB SATA hard drive in my Acer AOD150. What do I need and how can I accomplish this?
    President:
  • 1,623 Answers
Hello gadgeteer109....The AOD150 comes with a 160gb sata drive, so this should be a plug n play upgrade. Make sure the new drive is a notebook drive and not a desktop. You will need to install the operating system on the new drive... If you want, you can clone the original drive to the new drive before you swap them. You can download free cloning/backup software..Acronis has a free trial offer thats easy to use.You.will also need a 2.5 SATA drive enclosure, to hold the new drive while you clone the internal one to it before transfer to your computer, (these are cheap) and guess what... you can slap your old drive in it and have even MORE external storage! What a deal huh? The only tool you will need is a small phillips screwdriver.
TIP:
If you want to give the lilttle acer some rocket fuel while you have it opened up...swap out the 1GB of RAM for 2GB... A stick of Crucial 2GB 667 Mhz #CT25664AC667 DDR2 200-Pin SODIMM...will be another great plug n play upgrade for less than 25 buxs.
Hope this answers your questions and will fixya up...please take a minute to rate my response.
Posted on May 25, 2009
    President:
  • Acer Master
  • 1,314 Answers
This will work. There may be an adapter on your current drive that you must remove and put on the new drive in order for it to work.
Formatting WD SATA 500GB AAKS in larger than 137GB
The best software that can fix this problem is "Power Quest Partition Magic".It works like a dream for drives of any capacity!
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
My new 500GB WD SATA internal hard drive isn't recognised
Paul: Usually the drives come with a disk/cd from WD. Did you use this to format the drive?
Nov 19, 2009 | Computers & Internet
I have a 320 as my primary and i want 2 ad a 500 sata wd how do i set the pin jumper for secondary on my new one and the factory 320 has no jumper at all thanks
The SATA Drives do not need jumpers to set primary and secondary drive positions. Each sata drive gets it's own connection to the motherboard. Check you motherboard diagram, and make sure the 320GB drive is plugged into the 1st sata controler, and that the 500GB drive is connected to the 2nd.
Oct 11, 2009 | Western Digital Caviar 500GB Internal SATA...
Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
Aug 15, 2009 | Western Digital 500GB My Book World...
My AOD150 still does not work with the 500Gb drive but works fine in the external USB case. The "Setup" Identifies the drive and says it is okay when it is installed but when I try to load an OS it says...
is this an IDE or SATA drive. If it is a IDE be sure to correctly position the jumper setting on the front of the drive to either Master, slave or cable select. If master and slave dont fix the issue try Cable Select.
Jun 04, 2009 | Acer Aspire One PC Notebook
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Mar 29, 2009 | Western Digital Caviar 500GB Internal SATA...
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
http://www.wdc.com/en/library/sata/2079-001042.pdf
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Mike
Oct 28, 2008 | MSI P965 Platinum Motherboard
Acer Aspire One  PC Notebook Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
