Question about Lexmark X75 All-In-One InkJet Printer
Not powering up. I suspect the power supply. I have checked fuse on plug. Where can I get power supply.
Lexmark X75 is not powering up. I suspect it is the power supply. where can I get one? Regards, Ned
    Problem Solver:
  • 11 Answers
I would check ebay.
Posted on May 25, 2009
Power for the printer has failed
Please go through the following checklist to identify and fix the problem:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Nov 04, 2011 | Lexmark X75 All-In-One InkJet Printer
I own a Lexmark X75. I have plugged it in both to the mains and mac computer (via usb), but it seems to be dead. The fuse that was in the plug was not working. However, after putting a replacement 3 amp...
Hi Keith was the replacement fuse good to go has it blown again. more info and update please Steve, PSU should not be serviceable but with the correct tools and knowhow... .
I the new fuse was good (Tested on a low watt table lamp) then there is most likely a short in the X75.
Regards David
Dec 25, 2017 | Lexmark X75 All-In-One InkJet Printer
Am look for printer cord for an lexmark x75
I had that same Problem. I need the Power Cord, and Power Supply, that came with it. I called Lexmark, told them what I needed, and I receivec it, within two days.
I also needed the USB Cable, that connects to the computer. I found that at "Amazon.com." very cheap.
Oct 05, 2010 | Lexmark X75 All-In-One InkJet Printer
The power button on the machine will not come on but there is power supply in the charger as indicated by the green light and it is the same in whichever socket i try.
Great job on checking the green light on the power adapter's LED. Try these steps. Bypass any surge device or power strips. Plug printer straight to the wall power outlet. Try to make sure that you are plugging the power adapter in the correct position in its slot behind the printer. Plug it hard. If it won't automatically turn on, press the power button on the printer. If this doesn't help at all, I suggest you contact Lexmark Technical Support to further investigate the problem. I hope I can assist you more on this.
Jun 22, 2010 | Lexmark X5470 All-In-One InkJet Printer
I need a power supply cord for lexmark x75
Hello. Lexmark can better assist you with your request for the power supply cord for your Lexmark X75. You can contact them at 1-800-LEXMARK (1-800-539-6275).
Apr 07, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 printer/scanner
This printer/scanner, hooks up to the computer via USB. The USB cable goes into the back of the printer on the right hand side (opposite side from the power supply). The status blinking could indicate either; 1. No paper 2. No or very little, ink.
May 25, 2008 | Lexmark X75 MF All-In-One InkJet Printer
Will not power on
that might be from something internal..if the main screen illuminates, and the lights go green, the power supply is fine..it may be elsewhere.
Mar 26, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75
to RickwNJ,
The lexmark web site has the drivers, but not for Vista, iirc.
Best wishes
Jan 05, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
228 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
