Question about Kenwood VR-409 Receiver
Kenwood remote 0809 wont adjust volume or change inputs
The remote for some reason or another has stopped lettin gme adjust the volume or change inputs(cd/tuner/dvd/video1 etc) i have changed the batteries and reloaded the codes and still no solution. there is a funny looking symbol that appears at the top right side of the view screen and have no explanation in the remote manual as to what this is or represents. i changed the batteries to see if that was the problem but it has not helped. i am at wits end trying to figure out the problem,,,any help from you is better than nothing at all....thanks Mike
  • Anonymous May 25, 2009
    the icon that lights up is on the the remote and it is at the very top right. as far as the mode goes.....it wont even change modes going from (amp/video1/cd/dvd/ etc the button wont even change the modes i want..even when i put it manually in the mode i want and say put a cd in the volume still wont change either up or down but the little icon on the top right lights up... i couldnt find how to reset the remote either....it tells how to reset the receiver but not the remote. the remote manual doesnt even show the icon display in so i even know what it means? i am at a lost.....
    President:
  • Kenwood Master
  • 1,114 Answers
I looked thru the manual and the only two or three things I would ask would be: Is it in the right control mode? Amp/TV/DVD etc. silly I know but have to ask. Ithere a light or display that lights up when you push a button? if so, is it staying on? if so you could have a button thats jammed, it happens. Lastly it could be a microprocessor error in the remote and the remote needs to be reset. I didn't get to the process of how to do it but it is in the manual. That would be the last thing to try since programming alot of devices can be very time consuming! Lastly, the strange icon you see; is it on the lcd display of the remote or on the receiver? Hope this helps, if not send a reply and I'll dig some more for you
Posted on May 25, 2009
My kenwood kr-v7030 won't turn off anymore with remote or manually.
Either the remote battery are flat or the frequency settings have changed. You can check with the manual the type of frequency it uses to match the that of the Kenwood. Sometimes there are switches you can change to adjust the correct frequency. Others have a learning code set by the manufacturer and are usually in the operation manual. If you want to test whether the remote is transmitting the signal to the Kenwood or not, Please do this...
If you have a digital camera or smartphone camera, switch the camera on and look at the viewfinder or camera screen; for smartphone, in a moment, then point the remote to the camera lens and press the volume button, which keeps sending the signal to the to control the volume of Kenwood system. If you see the infrared light on the remote flashing, then the remote is fine.
Now, about the smartphone camera. Start the camera and switch it for video capture (filming) and then point the remote towards the camera lens, and likewise you should see the remote light when doing the same tests as you with the video camera. If the infrared light lights up when pressing on the volume, the remote is fine.
It could be Kenwood, which requires factory repairs, not by you.
Dec 22, 2014 | Kenwood Audio Players & Recorders
NO SOUND OUT OF RECIEVER, TURN VOLUME TO MAX AND CAN HARDLY HEAR ANYTHING
TURN THE VOUME CONTROL DOWN TO SOMETHING REASONABLE. MAX VOLUME IS ONLY USED TO DESTROY SPEAKERS.
Unmute it, de-select Tape Monitor, de-select M.Input.
http://www.retrevo.com/support/Kenwood-1060VR-Receivers-manual/id/478ci953/t/2/
Jan 27, 2011 | Kenwood 1060VR Receiver
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Kenwood DNX8120: Hard Buttons Stopped Working
so does anyone know short of sending the unit by to kenwood?
Dec 30, 2009 | Kenwood DNX8120 DVD Navigation Receiver...
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
No longer can change inputs on tv
mine did the same and i have been told that it is the mother board
Nov 21, 2006 | iLO 2600 Television
Kenwood VR-409 Receiver Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
