Holmes offers its Holmes Odor Grabber HEPA-Type Air Purifier, model no. HAP223-UC2, together with three Holmes HAPF22 Hepa Filters for $29.97 via the directions below. With free shipping,
that's $30 off and the lowest total price we could find for this bundle
by $33. Recommended for use in room up to 20-square feet, it features
air purification and deodorizing. To get this deal:
Lancaster air purifiers can have different models and designs, so the exact location and method for removing the filter may vary. However, I can provide you with some general guidance that should help you locate and remove the filter in most air purifiers.
1. Check the user manual: The first step is to consult the user manual that came with the air purifier. It typically contains specific instructions on how to access and replace the filter. If you don't have the manual, you can often find it online on the manufacturer's website.
2. Look for a filter compartment: Most air purifiers have a designated compartment or access panel where the filter is located. It may be on the back, side, or front of the unit. Examine the air purifier and look for any labeled panels or compartments that indicate the filter's location.
3. Remove the filter cover: Once you've located the filter compartment, you'll need to remove the cover or panel to access the filter. The cover may be secured with screws, clips, or latches. Use a screwdriver or your hands to undo the fasteners and carefully remove the cover.
4. Take out the filter: After removing the cover, you should see the filter inside. Depending on the model, the filter may be a single unit or consist of multiple layers. Take note of how the filter is positioned before removing it to ensure you can correctly replace it later.
5. Follow any additional instructions: Some air purifiers have specific instructions for removing the filter, such as pressing a release button or sliding it out from a designated slot. Refer to the user manual or any labels on the unit for any additional guidance.
6. Clean or replace the filter: Once the filter is removed, you can determine whether it needs cleaning or replacement. If it's a reusable filter, check the manufacturer's instructions on how to clean it properly. For disposable filters, it's generally recommended to replace them according to the manufacturer's guidelines.
Remember to consult the specific user manual for your Lancaster air purifier model to get accurate instructions tailored to your device.
1. Plug unit into outlet.
2. Press power ON/OFF switch to the ON position.
3. Allow unit to start running at low speed.
4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink.
5. Release both the UP and DOWN arrow buttons.
6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
It won't go out by itself.
There is a "RESET" icon next to the warning light. See the tiny hole? Get a small toothpick or something similar and simply insert, push, and watch the annoying light go out!
