Question about Hotpoint RGB745 Gas Kitchen Range
Westinghouse self cleaning oven manual or owners manual
We have a White Westinghouse self cleaning oven stove and I wanted to clean it and I can't find my manual..... my oven does not light, there is no gas smell even if left to stand for a while. is this problem solvable, especially me and how do I do it. You may also include any parts that I will require
fridgetech
  • 473 Answers
SOURCE: self cleaning hotpoint stove
Sometimes in self clean it can burn out the element.  Need to check the element with an ohm meter and see if it shows resistance.  If it shows open then the element is bad.  If it shows resistance then the element is ok.  Next see if you are getting 220 volts to the element when in bake mode.  If you are not getting 220 volts then the control is bad.
Posted on Oct 21, 2007
Amigaman
  • 248 Answers
SOURCE: Hotpoint self-cleaning oven
  I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
Posted on Oct 24, 2007
SOURCE: westinghouse self cleaning oven manual or owners manual
for the 8 button control ovens, white-westinghouse
turn both knobs to the lock setting (it looks like a padlock)
select the timer button (a clock with a line under it)
Increase the timer to 3 hours for heavy cleaning, 1 hour for light cleaning.
Then press start, (looks like a man running)
After cleaning let the oven cool down for 45 minutes
Hope this helps!
Posted on May 12, 2008
SOURCE: hotpoint self cleaning oven
1.get pet birds out of house.
2.take racks out of oven
3.slide door latch over if you have one(door should be locked)
4.push clean on control
5.set hours by pushing the arrows.i would set it for 2 hours
6.when finished let it cool down when it is cool enough the door will unlock or you can push the door latch back.at this point you will have a gray ash on everything,just wipe with paper towel.
7.be pround and smile at your clean oven.
8.oh don't forget to bring your birds in if you brought them out,the reason you have to bring them out is because the fumes are toxic to birds,but not to humans.
hope this helped
Posted on Nov 05, 2008
  • 23 Answers
SOURCE: Oven smells like gas when on
If the oven is new and has never been used, it should be cured before using. There is a curing your oven page in all manuals before use. You have to wash and burn off all the chemicals used in making the thing. Are u sure it sets off the smoke alarm and not the carbon monoxide alarm. Be careful some alarms are equipped with both now a days and people cant tell the difference. Get your gas company there to check it. Carbon monoxide is undetectable to the nose and is deadly so please be very careful! If there is smoke and u have cured ur oven then there maybe some old food on the burner, remove the bottom plate and check. If there is no smoke and no food on the burner then u need to change ur ignitor. It maybe old, cracked or both. Typical repair cost on high end range is 300 - 400 for 1 ignitor. Good luck. And I urge u to see if it is Carbon Monoxide!
Posted on Sep 04, 2009
Stove pilot is on but oven wont light?
How do you know the pilot is on? Most likely if actually burning gas pilot, you have a bad oven thermostat. or perhaps valve. If your question is about the light switch itself, that is a different issue and somewhat confusing.
Feb 27, 2015 | White-Westinghouse White Westinghouse...
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Westinghouse Self Cleaning Oven - Digital
hello susie,
try this site
http://kitchen.manualsonline.com/manuals/mfg/westinghouse/westinghouse_oven_product_list.html
May 13, 2013 | Kitchen Ranges
Older westinghouse stove won't unlock after self cleaning. I have tried to turn off main power and reset but won't work. Thanks
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2010 | Microwave Ovens
I have a 1950's westinghouse electric stove and I am looking for parts. Specifically the heating element for the oven?
I have a 1950s westinghouse electric stove for sale with the original owners manual in mint condition... please email me if you are interested... mgsromaniello@yahoo.com
thanks and i look forward to hearing from you
Jul 27, 2010 | Kitchen Ranges
White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Dec 18, 2009 | Ovens
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
Westinghouse stove
Turned the self cleaner on my electric stove although oven door at end of cleaning cycle would not open, it remained locked.
Would greatly appreciate any ideas.
Thanks
May 15, 2008 | Westinghouse Bethany Antique Brass- Indoor...
Many White-Westinghouse manuals can be found here: http://www.frigidaire.com/support/manuals.asp I had the same problem and was able to solve it. They didn't have the exact manual for mine (a KF450G), but they had one that was similar enough (KF580H) to solve this issue. Setting the knobs to clean is only part of the process, to get it to run you need to set the timer. Read the key information below transcribed from the manual: --- To set the controls for the cleaning cycle: 1) Close the oven door. 2) Be sure the clock shows the correct time of day. 3) Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will then pop out. 4) Push in and set the Stop Time knob for 2 to 3 hours past the Start Time. Example: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5) Turn the Temperature Control to CLEAN. 6) Turn the Selector to CLEAN. If all controls are set correctly, the oven signal light will come on and stay on until the oven reaches its cleaning temperature. It will then cycle on and off. --- There is more information in the manual, but it's much too much information to manually transcribe - I've only typed enough for you to get it working. Note that the LOCKED light won't light initially, it only lights once the oven exceeds 550 degrees. Once that light is on, the oven will not reopen until the temperature drops below that point, even if you stop the clean cycle. Be sure to empty out the storage drawer under the oven before cleaning.
Dec 08, 2007 | Kitchen Ranges
Hotpoint RGB745 Gas Kitchen Range Logo
306 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
