2001 Nissan Maxima Logo
Dana Benson Posted on Nov 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 Nissan Maxima service engine light stays on code from Auto Zone scanner is PO139 and PO138. What should my next step be to solve this problem.
2001 Nissan Maxima service engine soon stays on code from autozone scanner PO139 and PO138. What do these mean? Was told could be oxygen sensors could be bad and there are two of them on this car.Or fuel injector is leaking or needs to be cleaned? What would be my best next step to take to solve service engine light staying lit.
  • 1 more comment
  • Dana Benson May 26, 2009
    Thank you Jimmmyi for your answer to my question on codes PO139 and PO138 which you say are related to bank 2 oxygen sensors. Are these two oxygen sensors only accessible by jacking up the car and putting the car on jack stands? Are they easy to replace if I was to do it myself.
  • Jimmmyj May 11, 2010
    Not sure on exact position of sensors, try follow exhaust up from cat converter to locate the sensors, you may have to jack vehicle.If located it is a job that is easy enough to do just a matter of unscrewing and unplugging and screwing in correct new sensors.
    Both Codes relate to bank 2 which are more then likely picked up from the oxygens sensors, still can be caused by injectors, exhuast leaks, remove the oxygen sensors before the cat converter and replace.
Bill Boyd
Level 3:
Top Expert:
  • Nissan Master 53,816 Answers
  • Posted on Nov 16, 2017
Bill Boyd
Nissan Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11944240
Points
172802
Code p 0138 refers to 2 items
1--heated oxygen sensor(HO2S) 2 bank 1--high voltage ==causes --wiring short to positive --HO2S---ECM
2--oxygen sensor (O2S) 2 bank 1--high voltage ===causes wiring short to positive ---ECM
code p 0139 refers to 2 items
1--- heated oxygen sensor (HO2S) 2 bank 1--slow response ===causes --heating inoperative --wiring--ECM
2--oxygen sensor (o2S) 2 bank 1 slow response ===causes --wiring --- O2S
heated oxygen sensors9HO2S) are in the exhaust manifold before the cat converter
Oxygen sensors (O2S) are after the cat converter
it is indicated that the HO2S is faulty-
check the wiring and /or replace both sensors
5 Related Answers
Anonymous
  • 373 Answers
  • Posted on Jul 01, 2008
SOURCE: knock sensor
For replace the knock sensor on a maxima.
You need to remove the intake manifold.
If not, you have no access to the sensor.
This prosses require about 3.5 hour labor.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 23, 2008
SOURCE: Check Engine Light 1996 Nissan Maxima
The best way is to use a scan tool to clear the codes, that will turn off the light, also disconnecting the battery over night may work, but no completely sure about that, it varies from year to year.
Dennis Boxerman
  • 1306 Answers
  • Posted on Feb 20, 2009
SOURCE: 2002 maxima check engine light came on
First thing I would do is make sure you battery cables have a flawless connection. I had a Honda with a similar problem. I changed the battery cable and it all went away. Like magic. Sometimes these can be a simple fix.
Anonymous
  • 1201 Answers
  • Posted on Mar 16, 2009
SOURCE: check engine light stays on, need to know where oxygen sensor is
If you have an autozone or advanced auto near you take it there,they don't charge to put a scanner on it.
Anonymous
  • 82 Answers
  • Posted on Apr 24, 2009
SOURCE: 1996 Nissan Maxima oxygen sensor
hye there ,,there are 3   o2 sensors on your car,,one for each bank,,,and the 3rd sensor is located after the cat this one usually goes first,,,,just make sure you no if your cars an import or not as they can be different,,,then you should be safe when ordering ,,hope that helps,,,
2answers
Last week my check engine light came on Auto zone said it was mass air flow sensor the next day my car would not stay running like it was running out of gas
So you replaced the sensor and now the light is back on, right? Have you checked the code again to make sure it's still the MAF sensor code? If so, you've got a connector or wiring harness issue.
1helpful
I have 2001 Nissan maxima. In cold weather it want start. Warmer weather no problem. I took it to auto zone because the engine has been on they say it needs an 02 sensor will that keep a car from cranking...
Get yoursf a Hanes manual for your car. It will tell you where to look and where it is located. Eventually you can get a code reader from auto zone and the manual will tell you the codes and how to read them wo paying someone to do it
1helpful
A33 revs 2001
my book shows all Nissan engines as obd 2 compliant. Have some with a code reader who knows which pins to connect toread it . Next thing is to talk to a Nissan service centre as earlier models may have had a series of light flashes to read the codes.
Service engine light
do you have two o2 sensors after catalytic con.could be not good.
Turn off check engine light on 2001 Nissan maxima
hook an OBD-II scanner up to the OBD-II socket and press 'erase' codes on the scanner. This will turn off the light as long as the problem has been solved.
3helpful
2answers
PO138-PO139
P0138- o2 circuit high voltage, bank 1 sensor 2
P0129- 02 circuit slow response Bank 1 sensor 2
rear o2 sensor weak, replace it, will be the one after the caliltice converter.
2answers
I have a 97 nissan maxima, it was serviced in february but the service light stays on. why is the service light staying on?
this light may be the check engine light. it's misleading. I've seen two service engine soon lights in cars. one for check engine, one for service. have it checked with a scanner
1helpful
I have a error code of P0138 on 2001 maxima
PO138 CODE.REAR HEATED OXYGEN SENSOR MAXIMUM VOLTAGE MONITORING.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
