Please help. Our refridgerator leaks water from below. We've tried to locate the source of the leak but have had no luck. We moved the appliance away from the wall and removed the backing and the front lower grill and could not find the problem. In fact, after all that, by coincidence, we had no leak for almost a day but then it began to lead again the following day.
What's happening is when the fridge goes into defrost water goes thru the drain and is seeping into the crack by the damper which will run into the fridge section. Why? The drain doesn't come down far enough for all the water to go down the drain tube. Frigidaire has a new drain that is longer and will prevent this problem.
