Question about Polaroid FLM-3734B 37 in. LCD HDTV
Can't get HD channels selected on tv. Tried auto search with HDTV port connected and the menu selected to HDTV
I had the HDTV input selected and the cable box connected to the HDTV TV set, however when I scan channels the TV comes up with zero. I am connected to a digital catv box. How do I get HDTV activated on my tv?
    Problem Solver:
  • 6 Answers
Hello, the HDTV input is what you would use if you were not using a cable box.
You should connect your cable from the wall to coaxial input on the cable box, and connect an hdmi cable from the hdmi output on the cable box to the hdmi 1 input on your tv and then switch the tv to that input.
Tommy, HD Installations
Posted on Sep 07, 2010
The model # is: L42FHD37. I need to know how to set up an amplified indoor HDTV antenna. RCA multi directional serial # ANT1450BFW.
Attach the antenna to the antenna/TV input on the back of the TV. If you have a flat twin lead wire on your antenna, you'll need a co-ax converter. (Best buy, etc.) Power on the TV (and the amplified antenna) and use the Input button on the remote to select the TV input. Next use the menu button to select channels and then engage the auto-search option to memorize all of the available channels in your area.
Feb 29, 2016 | RCA Lg 42ls5700 42" 1080p Flat Panel...
Hit a RESET button, now I have NO T.V.
first select input source if menu visible then search channel manualy also store manualy auto function wil not work
Mar 10, 2014 | Generic Hiteker E32V7 32 in. LCD HDTV
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
How do you autoscan the olevia 232 t lcd hdtv? I connected an antenna and using a uneversal remote. it just sits there displaying 'no signal'
In the remote, select the input as antenna. It might be now lying as some other input. Normally the TV itself searches for channels. If it is not, go to menu in the remote control, select install-auto and press ok.
Jul 04, 2012 | Olevia LT37HVS 37 in. LCD HDTV
I just acquired a Toshiba 32HL95 TV and cannot get any hd channels although I have a digital cable box. I have tried using the coaxial, hdmi and video connections to no avail.
Try configuring your antenna input. Menu, Installation, Terrestrial, Input Config select your antenna 1 or 2 and > arrow over to select cable. Next auto program: under Terrestrial, Channel Program...this take some time.
Oct 23, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
376 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
