Question about HP Pavilion DV6700T Notebook
Hp laptop touchpad mouse problems
My hp dv6700 touch pad mouse will not work properly it starts to move around the screen randomly and i can not control it but sometimes i can. Going to control panel and going to mouse options and resetting the mouse in mouse properties and it works for a while
  • 3 Answers
IF U HAVE REPLACED THE DRIVERS TO THE MOUSE DEVICE THIS INCLUDES ALL THE PROGRAMS THAT THE SITE HAS TO RUN THEM. THEN ITS A HARDWARE PROBLE IN WHICH THE ACTUAL CONTROL FOR THE MOUSE CAN BE REPLACED.
Posted on May 25, 2009
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
My cursor will not move on my laptop screen
The reason your cursor will not show on screen is because the laptop jammed.
To fix this,
Try to shut down properly,
Then you remove the battery and reinstall it.
Turn it on back and your cursor will come back on.
Take care
Jun 21, 2010 | HP Pavilion dv6000z Notebook
How do I unlock the touch pad on my HP mini
I'm not sure what you operating system is but I'd suggest you go to your Control Panel and look for Touch pad and look at the settings there, If there's no Touchpad listed have a look in the Mouse settings.
May 11, 2010 | HP 2133 Notebook PC
HP Mini Touch Pad Right Mouse button auto click...
it may be a setting on the touchpad that you can set in control panel
Apr 24, 2010 | HP Mini 1000 Netbook
No cursor activity
Dear Sir,
Generally for compaq there is lock for touch pad you can see a moving lock below or above the touch pad. If locked the tochpad button,touch pad not sensitive.So open the lock and now you can move pointer using touch pad. see this pic
http://icerazerstudios.com/wp-content/gallery/random%20images/touchpad.jpg
there is black color button lock appear at the upper border of touchpad.
Jul 30, 2009 | Compaq Presario CQ60-204NR Notebook
Synaptics touchpad not working properly
Hmm give this method a try. Turn off computer remove AC power adapter. Remove the battery and press the power button for 30 seconds continuously. This removes the static from the system. This process is called as Power drain. This works in most of the cases. Good Luck !!!
Jun 04, 2009 | HP Compaq Presario F750US
Mouse cursor moving by itself
i have latitude c610 and same problem happens with me too. i think that happens when i finish my brakfat and without cleaning my hands start using the touch pad. what happens according to me is that small particles of food(eg bread/dust particles) stuck in the corners or the body wall where the touch pad ends and keeps pressing the touchpad, thus causing the mouse to move to one direction. when i clean the corners and sides of the touchpad, it starts working ok !!
thanks
Johal
Dec 12, 2007 | Dell Latitude C610 Notebook
try using a usb mouse first , if the problem still persists theres a problem with the hardware controller.
Oct 12, 2007 | Computers & Internet
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
HP Pavilion DV6700T Notebook Logo
383 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
