Question about Philips PET702 Portable DVD Player
Dvd player will not reconize a dvd when trying to play
My philips portable dvd player model PET702/37 will not load any dvds
  • Anonymous Mar 29, 2014
    My portable DVD player my venture will play DVDs but the picture goes out but the sound keeps going
    President:
  • 814 Answers
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
Grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
Jun 09, 2012 | Philips Televison & Video
Sony portable DVD player wont load DVDs
maybe the spindle motor is defective so it cannot read the disc. just bring that your dvd to sony service center to fix your dvd.
Jun 19, 2010 | Sony DVP-FX730 Portable DVD Player
I was given a mintek dvd player model mdp-1770 it is say no disc when there a dvd in it i have tryed recalbreting it by sliding back forth four time then loading a cd but it still reads no disc
If the unit plays CDs but not DVDs, then the LED for DVDs is burned out. There are separate LEDs for CD and DVD operation.
If neither plays, there is a more fundamental problem. In any case, only factory service will correct the problem with your "white elephant".
I have exactly this model.
Oct 07, 2009 | Mintek MDP-1770 Portable DVD Player
Philips DVP3020 plays CDs but not DVDs
Try running a good quality dvd cleaner. After the cleaning cycle try a known good dvd & see if it plays. Hope this helps.
Jan 22, 2009 | Philips DVP3020 DVD Player
READING NO DISK
the disk will not spin at all. the screen says no disk. this device is knew . what will cause this
Oct 08, 2008 | Philips PET702 Portable DVD Player
Cannot read disc
Had the same type of problem; I called Magnavox on this one. These DVD players aren't "guaranteed" to be able to read discs that were "burned"/homemade. They're only "guaranteed" to play commerically produced DVDs. If you're trying to play something that you made it probably isn't going to work.
Jul 31, 2008 | Philips Magnavox MPD845
Philips DVD Player model DVD622/37 wont play movies
Unplug/replug unit, try commercial dvd's again. If fails - call Philips- find out about replacement options
Jun 29, 2008 | Philips DVD 622 DVD Player
PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
Mar 16, 2008 | Philips PET702 Portable DVD Player
Won't play some DVDs
ya try cd lens cleaner ok they sell at store its a cd with litte brushes on it cleans lazor ok thx nick
Feb 11, 2008 | Mintek MDP-1010 Portable DVD Player
Philips PET702 Portable DVD Player Logo
811 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
