Question about Garden
Replace head My weedeater does not feed the line through properly and therefore I think the heads need to be replaced.
  • 284 Answers
Be sure it is wound properly in the correct direction and no bigger than .080 line?
Posted on May 26, 2009
Weed Eater Straight Grass Trimmer, 25 CC, 17-in. The trimmer line releases too easily and wastes most of the line.
Some of the weedeater heads are known to be ineffective and quite troublesome. Try Home Depot maybe for a universal type head that will hold and feed line the way you want. They have strimmer parts.
Aug 30, 2010 | Garden
I have a craftsman 32cc weedeater model 316791810. I am not sure how to replace the trim line. Is the line supposed to automatically length itself when the line breaks?
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
Weedeater starts fine but the string head will not spin. I removed the string head, and the shaft it connects to is not spinning either.
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Apr 15, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
Weedeater quick snap line spool
the part you bump on the ground to feed new line unscrews but typically its left hand threads so you think you are tightening but actually loosening. once off the spool chould come out then you may can tap on the head with a hammer coaxing it to come off.
Aug 04, 2009 | Garden
Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Jul 23, 2009 | Garden
Weedeater trimmer not engaging
maybe on reassembly the drive shaft did not align properly.
Jul 18, 2009 | Garden
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
