Question about RCA H5401RE1 4-Line Cordless Expansion Handset
Can't use the two compatible phones as an extension as I need to
Bought this phone and love it but needed an extension. So I bought the cordless handset, Model # H5401RE1-A, which is supposed to be compatible. I need to be able to talk on line one in my office and my business partner be on the same line in another part of the office using the handset as an extension. Can't do it, or at least I can't figure out how to do it. Can you help? If not, I need to return the handset immediately. Thanks, Susan Arnold
  • 65 Answers
SOURCE: All handsets cannot be used at the same time
Some of the cordless phones do not allow more than one handset to be used at the same time. Is there a transfer button on the handsets? Can you call from one handset to the other? If not the phones probably have to be used one at a time.
To get off speaker phone just push the speaker phone button again.
Posted on Jan 28, 2008
  • 281 Answers
SOURCE: I just purchased an extension
its wireless
Posted on Feb 28, 2008
  • 95 Answers
SOURCE: need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Posted on Mar 29, 2009
SOURCE: Lucent Partner Mail VS - need cordless phone
You can plug a analog phone into the "Aux" port on the back of the phone (provided it has one).
This will be the same extension as the corded phone, but give you mobility. If someone picks up the corded phone while you are on the cordless, they will hear your conversation.
Posted on May 26, 2009
SOURCE: RCA Executive Series 4-line model# 25413RE3-A
I was having the same caller ID. Then I looked up the phone on the RCA site:
Turns out there is no called ID on this model =(
Posted on Jun 17, 2009
I bought a base and one extension phone - no problem - bought another extension phone and it will not register
The new phone must fit into the base cradle for registering to even be attempted. You gave no model numbers, it is likely your newest handset is not compatible with the rest of your system... but we can sometimes "cheat". If the new handset is displaying "To register, place on base..." but it simply does not fit -- try removing the battery cover and see if wiggling the handset will allow the "charging" lamp to come on: then wait to see if it will register. You can find the base model number on a small sticker on the bottom of the base, the handset model numbers are on stickers under the battery.
Apr 09, 2016 | Vtech Cordless Phone Battery for 2429,...
How can i get my dwx207 to comunicate with a phone line
that is an extension phone only will not work without the control unit e;i answering machine that plugs into phone jack on wall
Apr 12, 2015 | Uniden Dwx207 Dect 6.0 Waterproof...
I bought a panasonic cordless phone TX-TG3821 wireless phone and connect it to our TDA200 but i have problem with the local extensions number not showing there is any configuration on TDA200 to make it...
your extension board should support CID.
KX-TDA0177 supports CID for analogue phones.
If you do not have this card then you need to exchange
your existing ext. card.
Oct 21, 2013 | Panasonic Lands Phones
Wanna add vtech5.8 handset to 6.0 (2 phone)
No, they are not compatible. One phone uses the 5.8GHz band to communicate, the other uses the DECT 6.0 protocol. You need two phones using the same scheme.
May 08, 2012 | Vtech Cordless Telephone (IA5859)
Colour on my extension cable are black red green and yellow how would i connect it to my wall mounted plate
Just bought twin panasonic home phone KXTG 7322 but phone extension cable to my old phone does not seem to be compatible - what phone extension cable will be compatible?
Nov 22, 2009 | Lands Phones
Searching for a phone with special feature
Yes you can buy cordless phones with transfer capabilities. We have several of them at where I work.
The unidens are some of the better phones on the market. All we have to do with them is when we receive a call is hit the talk button again and dial the number we wish to send the call to.
Any of the unidens should have this feature you could ask the salesman if you can plug them in to test.
An example of a good phone is:
Apr 24, 2008 | Northwestern Bell 35828-M2 Cordless Phone
GE 28041
dont try the disc, macs need full size ones it is likely to get badly stuck!
Feb 10, 2008 | GE 28041 Cordless Phone
Philips CD240 cordless phone
I have just bought a Philips CD240 cordless phone in spain, but the instructions afe not in english. Could you e-mail the manual in english to thank you so much
Jan 06, 2008 | Philips DECT5112 Cordless Phone
RCA H5401RE1 4-Line Cordless Expansion Handset Logo
65 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
