Question about Canon ZR70MC Mini DV Digital Camcorder
Tape transport stuck in open position. Will not take tape into unit.
Have a Canon ZR70MC that will not allow the tape transport to close. It is stuck in the open position. Tried to repair, with no success. Any ideas? Thanks!
Posted on Jan 07, 2019
    New Friend:
    Problem Solver:
  • 15 Answers
This is the most impressive article on your site, thanks for constantly working on replenishing the material router login
Posted on May 07, 2018
    New Friend:
I came across the same problem... the camcorder was out of power.. oops :/
Posted on Aug 10, 2014
    Problem Solver:
  • 10 Answers
It could be possible that the tape is in the wrong way or that the tape is the wrong size those are both reasons that it may not be closing
Posted on May 25, 2009
SOURCE:
How long recording time with a dv tape in canon zr70mc
That obviously depends on the length of the tape. With an 80 minute tape, you can record for 80 minutes in SP mode or 120 minutes in LP mode. With a 60 minute tape, the numbers are 60 minutes and 90 minutes.
Sep 11, 2013 | Canon ZR70MC Mini DV Digital Camcorder
Stuck head unit-- need help understanding the mechanics of a tape deck.
The solution to the problem comes from recognizing the type of transport the unit uses. This can be discovered by looking at the working side or by a person who has some experience working on these. Chances are there is a stuck flywheel assist mechanism and just because the belts are no broken or not turned to goo, that does not mean they are good. Also does the capstan motor turn? If it does not, there is no way the mechanism can right itself and that might mean a new capstan motor. Dual cassette decks were built for profit not for a long lasting unit- that is why the thrift shops should be full of them and why most of them will not work.
Aug 11, 2012 | Sony Audio Players & Recorders
Tape is stuck
Tapes commonly get stuck in cam operated transports. The belt gets too lose and can not turn the attached cam gear- it is easy to release a tape- you open the unit up and remove the power first. Find the pulley that has a loose belt on it and turn it by finger- do not apply a lot of force just about what the belt would do. At some point the deck will open. Then you can remove the tape.
Jan 31, 2012 | Pioneer Audio Players & Recorders
Service error 6000. Cartridges won't slide to the left
4. PRINTER TRANSPORTATION
This section describes the procedures for transporting the printer for returning after repair, etc.
1) In the service mode, press the Power button to finish the mode, and confirm that the paper lifting plate of the sheet feeder unit is raised.
2) Keep the print head and ink tanks installed in the carriage.
[See Caution 1 below.]
3) Turn off the printer to securely lock the carriage in the home position. (When the printer is turned off, the carriage is automatically locked in place.)
[See Caution 2 below.]
4) To further secure the carriage to prevent movement from the home position during transportation, make and use a fixing tool in the following procedures:
i. Fold an A4-sized paper 5 times, and wrap it twice with tape, as shown in Figure A below (to prevent the fixing tool from caught into the inside of the
printer).
ii. Insert the fixing tool between the carriage and the main case unit, and securely fix it with tape, as shown in Figures B and C below.
Note: The tape should be similar to the polyester tape used at shipment, which will not easily be torn or removed, or leave adhesive on the unit when
removed.
Leave a sufficient length of tape to fix the tool so that the tape end is easily seen even when the cover is closed, so that the user will remove the
Aug 23, 2011 | Canon Pixma iP6210D InkJet Photo Printer
Conon zr200 tape loading assembly will close with no tape in but will not close with tape in carriage
The tape transport mechanism cannot fully engage the tape to the head. When a tape is inserted, the tape guides have to pull the tape from the cartridge and send it towards the head. There is a sensor in the carriage that activates the transport to perform its' job. When that sensor is not enable, it will just allow the door to close and the tape guides will remain stationary. Basically, it needs to be taken apart and fixed or realigned.
Nov 13, 2010 | Canon ZR200 Mini DV Digital Camcorder
How do you put video from your camcorder to your computer?
With a Canon ZR70MC camcorder, you can record video onto miniDV tape, or onto the SDmemory card in Card Camera mode.
To access video on the miniDV tape, you will use the DV cable (IEEE 1394 aka FireWire). Connecting this cable to your windows computer will allow you to transfer high quality video using the software supplied on the digital video solutions disc, or just about any other windows video editing software.
To access videos stored on the SD memory card, remove the card and place it in a card reader connected to your computer, or attach a usb cord to the camera and the computer. Video stored on the memory card is limited to 10 second clips @ 320x240 resolution.
Oct 11, 2009 | Canon ZR70MC Mini DV Digital Camcorder
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Canon ZR 600 tape won't load
The capstan motor is broken and needs replacement. You could send it in for repair but it wouldn't be cheap.
Dec 31, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Aug 07, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Tape won't come out!
I had the exact same problem, and just by dumb luck, I managed to get the tape compartment to pop open after trying hundreds of things. Maybe this will work for you too...who knows??? What I did was to first remove the battery and AC power to "reset" the camera (I guess). I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VIOLA!!! Like I said, it may be dumb luck, but I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism...dunno???? BTW, when I was having the problem, the mechanism would "click" 3 or 4 times while trying to move the tape out. Good luck!!! I hope this helps someone!
Jul 24, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Canon ZR70MC Mini DV Digital Camcorder Logo
6,559 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
