Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20 lights red not green
When powered on lights are red not green
screen is black but audio is present
SOURCE: No audio on RCA d52w20
i don't know what it is but my tv is doing the same thing if you find out will you please let me know.
Posted on May 25, 2007
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Posted on Jun 29, 2008
video-tek
  • 150 Answers
SOURCE: RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Posted on Jun 05, 2009
  • 13 Answers
SOURCE: RCA D52W20 Rear Projection, Green and red shadow
Makaba is incorrect. This set does not use the STK IC's found in many rear projection sets.
All you need is a $3 fuse and be sure to resolder the joints at the flyback.
Posted on Oct 01, 2009
SOURCE: rca d52w20 power light blinks 9 times and then 5
rca d52w20 nine blinks after five blinks
Posted on Feb 16, 2010
Does a RCA D52W20 have a red LED illuminated when the TV is not powered on? This would be the same location as the green LED power on.
Yes it has a stand by light and it is red . once the power on is started it checks the rest of the command lines from micro and starts the initialization process once all are satisfied it un mutes the picture
. however it appears your fighting a one problem and possibly compounding the problems now .
Dec 10, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can u help me my RCA TV will not stay on keeps turning off.
Palaboy, where can i buy this part at ? R73 .0087uf h 2000 vdc. the one in red rectangle.
Jan 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a rca model d52w20 52in rear projection with green screen the green tube has been replace and the board at the bottom of the tube has been replaced also and it still has green screen and a humming...
can you pull the green crt board and carefully check to see if the 200volt supply is present that one cause for over satuations of the crt if it is not there you need to trace back for the cause
Dec 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W23 No picture only sound
there is defective parts on your t.v, you have to consult it to some experts near you if you dont know how to do some electronics repair.
Aug 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20?
ok ...first question ... what happens when u push menu?...do you get any osd...on screen display...menues volume.. channel number. HOw bout any sounds... the light comes on and the stays on..?
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
