Question about Microwave Ovens
Bulb blown on Russell Hobbs CJ/AL28 microwave
Hi - The bulb has blown on my Russell Hobbs microwave.. in the manual it says do not attempt repair.. but how hard can it be? Can anyone tell me how to do this? I don't really want to call out a technician to change a bulb..
Many thanks
Tony
  • 180 Answers
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
Posted on May 26, 2009
Hi, The bulb has blown on my Russell Hobbs microwave, and the manual say to call out a technician! I don't have a top cover to open so can't replace it myself, and my manual doesn't show how to replac
The "top cover" is the wraparound sheet metal enclosure. It has to be removed to replace the lamp. The attaching screws often are special and require a special tool for removal. Se sure power is disconnected before beginning removal! Once inside, there are high voltage points to avoid while replacing the lamp. Reverse the procedure to reassemble the enclosure.
Sep 18, 2014 | Microwave Ovens
Hi i have a Russell Hobbs HOB CJ/AL28 Microwave.the microwave has stopped heating things up.Oven part works ok.Any suggestions would be most help.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARRAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
Russell Hobbs HOB CJ/AL28 Microwave not worring
it is easy to fix if you know what to do but it is best sent to a local repair shop
May 01, 2010 | Microwave Ovens
Bulb blown. How do I change it?
Hello there :
first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
I hope this is very helpful for you
Best regards Michael
Dec 03, 2009 | Zanussi ZMC30STQX Convection Microwave...
Russell hobbs cjs28 microwave oven user manual
sir i have a need of owners manual of russel hobbs cjs28 if u have it then plz... send me immediately on this address rehmanmunawar@yahoo.com
Sep 17, 2009 | Microwave Ovens
KEN CJ/AL28 Microwave
you should try a local wal-mart or even radio shack as these bulbs are somewhat common in many small appliances. Also, you may check at a local appliance repair shop.
Mar 24, 2008 | Microwave Ovens
Microwave Ovens Logo
883 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
