My son has a Canon A720-IS camera, maybe 2 years old and suddenly it will not turn on. Stone, cold dead. We have changed batteries for good ones (always NiMh rechargeables) and have checked there is 3V from the Lithium coin cell. He has taken easily a thousand pictures and is pleased with the camera. Does anyone know if it's repairable please? I hate to throw something like this away.
Thanks in advance fo yout input.
Comments:
May 26, 2009
- Thanks t00nz for those tips, but they're not the solution for this one :-( The lens is retracted and the lens cover is closed. The battery contacts are OK, the door switch is present and there is not a rattle of broken-off parts. Tried powering on without the memory card.
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try. You can skip the battery comments and focus on the other suggestions in the article:
- If you've tried all the above, and there's absolutely no reaction at all from the camera (no blinking lights, nothing), then it's likely a blown fuse. Unfortunately these are very tiny, internal to the camera, and are soldered to the circuit board. They're primarily a safety feature to prevent overheat and fire, and are not really meant to be replaced. Also there's likely another problem that caused the fuse to blow, so if you did replace the fuse, it can happen again (usually gummed up gears in the lens assembly). Sorry that I don't have any better suggestions for you.
i have had this camera for about a year and a half and when i first got the camera i was raving to...
(More)
i have had this camera for about a year and a half and when i first got the camera i was raving to everyone over the incredible battery life i was getting. i could take hundreds of pictures with a single pair of AA's. now I am lucky to get 10 pictures before the camera shuts off and says "Change the batteries" i have tried rechargeable batteries and right out of the package energizers please tell me if there is somethign i can do.
Every time i power up my canon powershot A720 is, it asks for the date / time prompt. I have changed...
(More)
Every time i power up my canon powershot A720 is, it asks for the date / time prompt. I have changed the CR1220 battery twice but it still does it.
i dropped my camera ,still works..but the latch for the battery doesn't close properly,is there...
(More)
i dropped my camera ,still works..but the latch for the battery doesn't close properly,is there anything i can do.Thanks
Same problem as many others. screen says "change batteries" and shuts off. Even with new...
(More)
Same problem as many others. screen says "change batteries" and shuts off. Even with new bateries the Camera won't take pictures or videos, still flashes as low battery and shuts off. I tried reformatting and reseting the camera. nothing helps. please let me know what the solution to this problem is.
