Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
What oil do I put in my 4-stroke Troybuilt weed trimmer?
I can't locate the manual and can't find the oil supply container that came with the unit.
  • 1,305 Answers
According to troybuilt, here's their info.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
K
Posted on May 25, 2009
My yard machines weed wacker 4 stroke gear box overheats or very hard to turn. How do I fix that?
I would try putting some high quality gear oil in the box and see if that helps
Apr 25, 2014 | Yard Machines Garden
Is model460 148cc engine 2stroke or 4stroke
4 stroke. Is there a dipstick on the engine? check the oil level. If there is a dip stick it is a 4 stroke and no gas -oil mix is needed. Mostly 2 cycle are for weed trimmers etc where weight needs to be light and where an engine will be used in all positions vertical, horizontal etc. usually a smaller type engine say like 30-50 cc.
Dec 12, 2011 | Yard Machines Garden
What is the fuel mix for a 128cd model weed eater
A good fuel mixture ratio for any 2 stroke weedeater or chainsaw is 50:1. That equals out to 2.6 oz of oil per gallon of gasoline. Most 2 stroke oils can be bought in pre-measured containers at hardware stores or small engine dealers. It is best to not mix more than 2.5 gallons at a time. Hope this helps, Daniel.
Sep 14, 2011 | Husqvarna 28cc Gas Line Trimmer
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Do you add the oil first or the gas first?
If you're talking about mixing two-cycle oil with gas for a two stroke motor, always mix it in a gas can then pour it in the weed eater. It's easier to put the oil in the gas can first then fill it with gas to get the two mixed well.
Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What mix of 2 stroke oil do I use for a Stihl hedge trimmer, in other words how much 2 stroke oil do I put into 5 litres of petrol. Thanks.
if using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
May 29, 2010 | Garden
As dum as they come
dsc-w110 sony cyber shot flash on or auto mode capture picture idark but flash off condition picture is ok
Mar 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Confused a little
A 4 stroke motor does NOT have Oil in the Fuel. There is NO fuel mixture. Just use regular gas. The only place you need oil is in the sump, and regular 20/30 motor oil will be fine.This only needs to be replaced when low on dipstick in crankcase.
Hi im after the fuel mixture for a 125L husqvarna straight shaft brush cutter.thanks
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Jan 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
1,013 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
