Question about Hobart A200 Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
I have an old Hobart a-200 Serial #1060993. RUNS HOT & SHUTS DOWN. She has no power left. She can't mix pizza dough anymore.
    Scholar:
  • 81 Answers
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
Posted on Jul 25, 2009
HOW OLD IS MY MIXER
The Hobart A-200 is an 80's product. These first came on the market around 1985. There is no way to date the one you have without examining it.
The best estimate is 25-30 years old.
Sep 22, 2015 | Hobart A200 Stand Mixer
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
Hobart A-200 3943. Having a problem with torque.
Check your recipe against the capacity chart found here: http://www.primasupply.com/images/hobarta200.pdf
You may be overloading the unit. Hope this helps.
Oct 13, 2009 | Hobart A200 Stand Mixer
Contact overload for h600 3 phase mixer
I'm a hobar tech and repair these often.The problem is the overload contacts are opening so the motor doesnt burn up.I know the mixer is old and the overload has weakend over time or simply the mixer is being overloaded with too much product.Did you just get this mixer?change the recipe?mixing pizza dough and adding ice?Any new employees if it's in a buisness?
Mar 19, 2009 | Hobart H600 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Hobart M-802 mixer
Your overloading the mixer with too much product or not enough water,cut the batch down,the motor protection board is doing its job by shutting off.
Aug 06, 2008 | Hobart Food Mixers
Hobart A-200 Motor Direction
No, do not swap hot and N.
First, verify rotation. As the attachment shaft rotates, it should push the engagement pin into the keeper slot. Looking down on top of the mixer, the planetary should rotate clockwise.
If the unit runs backwards, does it start slow? Can you get it to run either way by giving it a push start before turning on the power? If so, your start switch is not working properly. (Which is my guess) Check your capacitor.
There is mechanical and electronic start switches. (Metal arms and a contact or a little gold rectangular metal can.)
Check it out and let me know what you find -- Mike
May 19, 2008 | Hobart A200 Stand Mixer
Hobart A-200 serial # ?
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
Mar 02, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
519 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
