Question about Toshiba Satellite A135-S4427 Notebook
Computer will not boot into windows
Bootmgr error on startup. Put in restore disc and clicked repair. no windows operating system recognized.
  • tommybe11b May 26, 2009
    Thanks tried reloading operating system and that failed. I found out my problem was the Hard Disc went Kaput. Thanks anyway.
The only way you could do that is to reinstall the operating system you already check the repair and still no go
Posted on May 25, 2009
BOOTMANAGER IS MISSING
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
The latest versions of Windows, including Vista and 7, use the Windows Boot Manager to read the boot configuration files and data in order to load your Windows Desktop.
If any of these files are corrupted or damaged, you will see a "BOOTMGR is missing" error. Fortunately, you can use a number of Windows tools to repair or replace the BOOTMGR or any related file that may be the cause of the problem.
Insert your Windows installation CD disk in your computer's CD drive and restart the computer.
Press "F8" repeatedly while the computer boots up.
This command enters the "Advance boot options" screen.
Select the "Repair my computer" option and then press "Enter."
The System Recovery Options screen opens.
Select the "Startup Repair" option at the top of the list and click "Next."
The utility will scan your system for the cause of the BOOTMGR problem and repair it.
Hope this helps
Oct 30, 2012 | Computers & Internet
Bootmanager missing
Hope this helps
Oct 30, 2012 | Microsoft Windows Vista Home Premium with...
Bootmgr missing error on startup
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Oct 09, 2012 | Dell Studio 1737 Laptop
Kenapa pada saat penginstalan laptop muncul tulisan BOOTMGR is compressed..?
google translate
why at the time of installation the laptop it says BOOTMGR is compressed
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
bootrec.exe /fixmbr
hope this helps
Aug 09, 2012 | Computers & Internet
Bootmgr missing
1. the operating system that you might have might be windows vista or higher
2. First must you boot must boot to your windows vista/windows 7 OS disk
3. keep on hitting next until you get to the part that says Install Now
4. There is an option to click on Repair my computer
5. Keep on hitting next until you will be given a list says startup repair, command prompt,system restore
6. Choose Startup Repair keep hitting next until windows restarts
7. If it fails repeat steps 2 to 5 and choose System Restore, Select a
Date that computer is up and running
Hope this Helps
8. Select a date that the computer was up and ru
May 23, 2011 | Acer Computers & Internet
Missing bootmger
Fixing the "BOOTMGR is missing" error isn't too hard; here's how.
The day before yesterday I was testing out a program with several system utilities built in. One of its components left my computer in a bit of a mess - no icons anywhere and other assorted woes. I had set a system restore point before I ran the program, so I thought I'd do a system restore. System restore gave me a message that it couldn't restore my files. I decided to restore a disc image I had made a short while back. When I booted up the computer I got a message:
BOOTMGR is missing
Press Ctrl+Alt+Del to restart
I stared at it the white letters on the black background for a few minutes, while the cursor blinked back at me. After some searching (on another computer) I had some solutions.
Barring any hardware errors, here's how to fix that error:
  • Insert your Windows Vista or Windows 7 disk into your DVD player and restart your computer.
  • The next screen you see should have the Language, Time and Currency and Keyboard boxes.
  • In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
  • Click on "Repair your computer"
  • Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
  • Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
  • You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
  • When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
  • At this point, you can remove the DVD, reboot and everything should be working.
Two sites I found helpful are BOOTMGR is Missing at about.com and cyberstorms How to fix "BOOTMGR is missing" in Windows Vista
If the method outlined above doesn't work, try Solution #2 at the cyberstorm link.
Oh, restoring the disc image went fine and all is well. All my data was backed up (somewhere other than the hard drive Windows is on) so that was one thing I didn't need to worry about. Windows Vista and Windows 7 are the only Windows operating systems where this message appears; XP users don't have to worry about this one.
Mar 29, 2011 | Computers & Internet
Toshiba satellite L300 will not boot up. error code 0xc00000e9
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
Mar 07, 2011 | Computers & Internet
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
Bootmgr is missing
BOOTMGR is missing
Feb 18, 2011 | Acer Computers & Internet
Black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
May 15, 2009 | Compaq Armada E500 Notebook
Toshiba Satellite A135-S4427 Notebook Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
