Question about Frigidaire GLEQ2152ES Electric Dryer
GLEQ2152ES the error "PF"
I have a Frigidaire dryer GLEQ2152ES and display the error "PF" Can you help me
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
Posted on Jul 03, 2009
    Sergeant:
  • 212 Answers
Pf is power failure. push cancel and it should clear
Posted on Jun 20, 2009
2 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: pf error code on frigidaire gleq2152es
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Did you check the owners manual first to see about the blinking codes?
Usually the codes mean you just have to have factory service remedy the problem!!!!!!!!!!!!!!!
This is a situation that you will need service!
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Feb 17, 2016 | Frigidaire GLEQ2152ES Electric Dryer
What do error PF mean?
It seems like problem is in main control board or problem could be related with other components .As PF stand for power failure in dryer and it could caused by many factors
Mar 04, 2013 | Frigidaire GLEQ2152ES Electric Dryer
The dryer works, but dont heat, and apears the PF on the display
Hi
Error PF means power failure, it appears when the dryer is unplugged or when an intermittent power failure is observed by the dryer. If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Start dryer and it quits and displays pf on screen?
The pf is for power failure .If the voltage is correct going to the unit 110 to 120 volts on each leg of the circut. then the issue is with the machine control board not sensing the voltage correctly. and the control board will likley have to be replaced...
Hope this helps with your concern..
Aug 14, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dishwasher goes through part of a cycle and then comes up flashing PF
you need to check the main power wire to the dryer there may be a loose wire that is causing the power failure message to display also check and make sure the circuit breaker is in good condition
Jun 28, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Hi, I have been using my dryer with no problems today then all of the sudden an hour ago it has a error code PF. I know that it means power failure but how can I correct the problem? Thanks!
if the power did not go out and you have a pf code you may have loose conection to the power cord. reset the dryer (cancel button)
and if it returns check the conector block where the the power cord connects.
Dec 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Pf error code on frigidaire gleq2152es
DEAR FRIEND,
A&E Factory Service
1(800) 905-9505
Thank You
Bless you,ngfam1
Aug 25, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Error PF
PF simply means power failure, not really a fault as much as a visual indicator to let you know that you've experienced one. i would check your electrical outlet,sounds like a loose connection
Mar 04, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
721 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
