Question about Frigidaire FWS833A Top Load Washer
Hi, my washer will fill, agitate, stop and not drain or spin.
Hi, I have a Frigidaire glws1749as5 washer. It'll fill, agitate, stop and not drain or spin. The timer also stops; it won't drain or spin on any cycle. The door lock doesn't lock the door.
I checked for the bomb to spin manually, I drain it to check for clogged tubes, the door switch is good also. But still, I can’t get it to work, do you have any ideas?
I'll appreciate any comments.
Hi everyone, I found the solution to my washer problem. I checked the lid switch and it was ok, but the lid lock was damaged. I opened the lock and I solder it and the problem was solved.
I hope this info can help someone.
Posted on May 28, 2009
I have a frigidaire heavy duty extra large capacity 2 speed combination 3/4 horsepower.washer dryer. The washer fills,drains and spins. It does Not agitate. I can spin the tub counter clockwise. The thingy...
Hello Marjorie, thank you for your post!
From the information you have provided water will fill, drain and spin but your Frigidaire washer is not agitating. This could be a problem with your motor, belt, or pulley. Locating the problem is not a simple DIY job and I would suggest seeking assistance from a professional. They have the appropriate tools needed to disassemble your washer and prevent any future issues. I hope this information is helpful to some degree. -Matt
Mar 10, 2015 | Frigidaire Washing Machines
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Washer not draining water
It is likely that something is stopping the pump from operating. Most machines allow access to the pump to remove coins etc which can stop the pump operating
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer stopped after wash. Would not drain or spin. Will fill.
Hi, can I get a Model# and make so I can try and assist you?
Vic
May 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
608 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
