Question about Adobe Premiere® Elements 2.0 Full Version for PC
My system will not support the SSE2 instruction set I have: HP pavillion 725n Processor: AMD Athlon(tm) XP 2400+ Version: x86 Family 6 Model 8 Stepping 1 Speed: 1996 MHz edit
HI! I'm trying to instal Adobe Premiere Elements 2.0 and get the error that my system will not support the SSE2 instruction set this is my processor can I download a fix? I went to Intel web site and got no where AMD Athlon(tm) XP 2400+ Version: x86 Family 6 Model 8 Stepping 1 Speed: 1996 MHz
    Problem Solver:
  • 10 Answers
There is no solution except to upgrade your processor if that is possible. Premiere Elements will not run without SSE2 support.
Posted on Jun 22, 2009
What is sse2
SSE2, Streaming SIMD Extensions 2, is one of the Intel SIMD (Single Instruction, Multiple Data) processor supplementary instruction sets first introduced by Intel with the initial version of the Pentium 4 in 2001. It extends the earlier SSE instruction set, and is intended to fully supplant MMX. Intel extended SSE2 to create SSE3 in 2004. SSE2 added 144 new instructions to SSE, which has 70 instructions. Rival chip-maker AMD added support for SSE2 with the introduction of their Opteron and Athlon 64 ranges of AMD64 64-bit CPUs in 2003.
May 04, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
System Manufacturer Gigabyte Technology Co., Ltd. System Model GA-MA790X-DS4 System Type X86-based PC Processor x86 Family 16 Model 2 Stepping 3 AuthenticAMD ~2712 Mhz Processor x86 Family 16 Model 2...
Hello my friend,this is could happen because of driver problem or and more common operating system failure.Try to reinstall the windows again but i recommend you to make a clean install (format hard drive and install the new windows)
Feb 06, 2010 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
I cannot install my autocad 2010 because it says that my processor is not sse2 compliant. is there a way to install it for free?
Hi
I'm sorry you can not use the program with your old computer, the requirements are.
  • Intel® Pentium® 4 or AMD Athlon® dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
If your processor does not have SSe2 technology support, it is too old to run the program, buy a new machine. Or use a older version of autocad. your computer must be around 5 or 10 years old or more. SSE2 has been around since 2003.
Quote http://autodesk.blogs.com/between_the_lines/2009/03/sse2-cpu-support-requirement-for-autocad-2010.html
23 March 2009
SSE2 CPU Support Requirement for AutoCAD 2010 I will try to not geek out and confuse you on this post. With AutoCAD 2010 there is an AutoCAD 2010 System Requirement to have a CPU (essentially the computer’s brain) with SSE2 support. SSE2 is an Intel CPU instruction set (SIMD Extension 2) which is essentially technology to replace the old MMX extensions which are half as slow in many data and math operations. Most current systems will support SSE2 except an old AMD CPU system over 6 years old. AMD Opteron, Athlon 64 both support SSE2 and have since 2003.
So why SSE2 requirement in AutoCAD 2010:
In developing software there is a limit on how old of technology you can effectively support without impacting current hardware and software users. In the case of AutoCAD 2010 adding the SSE2 requirement this increases performance for customers using current hardware. Many areas improve in AutoCAD such as OSNAPs.
I said I would not geek out so I will not go into details on floats, floating point, and registers. Your experience may vary but the change was made for some performance benefit of current hardware.
Bottom Line: Increasing performance is a good thing!
End Quote.
Dec 15, 2009 | Autodesk AutoCAD 2010
I have a hp pavilion7935,amd athlon 1.3 ghz,would like to upgrade
You have a wonderful machine and it should not be giving any problem. Are you currently facing any specific problem such that you need to maximize its performance. Well there is Hardware solution for that. You could try to tweak its performance by using the software-- Advanced System Optimizer 2.2 or 2.2 available for download(free) from uTorrent or Limewire....sodeep
Mar 31, 2009 | HP Athlon 4, 1.3 GHz (277517001) Retail...
Nec 17'' multisync lcd monitor not working properly
What is the problem? Did you try plugging it into another working computer?
Mar 03, 2017 | NEC AccuSync LCD71VM 17" LCD Monitor
SSE2 enabled processor
It is most certainly. SSE2 was introduced with the Pentium 4 and all AMD Athlon 64's have it.
Jun 25, 2008 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
System specifications
Here's the HP Support link for your laptop.
Apr 23, 2008 | Computers & Internet
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Jul 16, 2007 | Compaq Athlon XP 2000+ , 1.67 GHz...
Adobe Premiere® Elements 2.0 Full Version for PC Logo
381 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
