Question about Panasonic NN-T694SF Microwave Oven
Panasonic NN-T694SF smoke, shuts itself off
Panasonic NN-T694SF. After 2 years, now in about 5-10 sec. burning smell, little smoke and Oven shuts itself off. Any advise ? Is this model DIY friendly ?
  • regionseven Dec 13, 2008
    We have the identical problem and have owned ours about the same length of time. Ours lists 1250W instead of 1300. Do you have any idea how much this will cost to fix?
  • Anonymous Mar 15, 2014
    I have a panasonic microwave grill oven NN-K652 and it is not cooking the food or warming the drinks enough. The machine is 19 years old but has had very little use
  • Panasonic Master
  • 9,098 Answers
In most cases, this is a problem with the inverter or a bad transfotmer.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Oct 22, 2007
Hi my oven suddenly started making loud weird noises and now does not heat any food. I smell smoke. What might be wrong?
Seems to me that your magnetron is a goner, check also the antenna shield, cover inside the oven cavity and replace both, you may need to clean and repaint burn surfaces inside oven cavity.
Jan 08, 2016 | Panasonic NN-S676BA Microwave Oven
Our s333 panasonic microwave stops working after 1 second?.. it just shuts off?? can you advise?
It probably requires a new magnetron or an invertor board or both. Take it to an authorised Panasonic repair agent for an estimate for repair.
Jan 24, 2011 | Panasonic NN-T694SF Microwave Oven
Panasonic microwave S333 just stopped suddenly. I see on the internet that this has happened to others after about 2 yrs use. Any solution suggestion is appreciated.
Did it show an error code in the display?
If it showed H-98 or similar the magnetron has failed.
It is not a customer repairable item. Take it or have an Authorised Panasonic service centre look at it.
Jan 19, 2011 | Panasonic NN-T694SF Microwave Oven
Panasonic NN-CT776SBPQ, just 2 y old, burning smell advise what could be the problem and how much it cost\r\n
check if the smell is coming from within the cabin. If so due to non usage of food covers some food particles ccould have got stuck while on heat to the sides of the cavity and results in heating and smoking. If so clean well with a dry clot and wipe out any moisture on the magnetron fitting slot.
However if the smell continues, check the capacitor to the magnetron or the magnetron or the main transformer itself.
You must open the cover and check for the origin of the smell.
estimate cost and decide.
Creddit if the advice helps.
Aug 25, 2010 | Maytag MMC5000 Microwave Oven
It is actually NN-T695SF, it will not warm food. It powers up then goes dim, then powers up then goes dim, it keeps doing that. Food comes out cold.
Hi, if it is an inverter microwave and the problem is cycling every 2-3 seconds, my experience is the magnetron has most likely gone short circuit and the inverter board is shutting down to protect itself and then restarting, hence your symptom.
DO NOT try to test this unless you are experienced with extra high voltages - the voltages present/stored in a microwave even when powered off can kill you.
Aug 13, 2010 | Panasonic NN-T694SF Microwave Oven
My Panasonic Inverter S333 just suddenly stopped working. I get a "refer to manual" message. Manual has no help to offer. Even the "signal bell" sounds a little off. Up until today, it was working just...
My Panasonic Inverter S333 just suddenly stopped working April 30 after I used it for only two years, no showing in panel. It will run only when I open the door, it is strange.
Apr 19, 2010 | Panasonic NN-T694SF Microwave Oven
It shut itself off after 7 min. Microwave....
Sounds like an overheating, probably burnt fuse, maybe due to a bad fuse holder. or for that matter just a blown fuse for a variety of reasons. Will have to check fuse or see where it is losing power
Jun 26, 2017 | Panasonic NN-T694SF Microwave Oven
Faint buzzing sound smoke coming from back
The high-voltage transformer (or inverter transformer) has probably failed.
Oct 24, 2007 | Panasonic NN-T655SF Microwave Oven
Panasonic NN-T694SF Microwave Oven Logo
635 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
