Question about Dell Dimension 4600 PC Desktop
How do i format it
I need to format my compture
    President:
  • 156 Answers
Process for Windows XP Re-installation
WINDOWS RE-INSTALLATION WILL WIPE OFF ALL THE DATA.
1. Insert Windows XP operating System Disk In The CD Drive.
2. Shut Down The system.
3. Disconnect Everything Except Mouse, Keyboard, Monitor And Power Cable i.e. something like internet, printer, USB PEN DRIVE or External Hard Drive.
4. Restart your system and start tapping F8 key on the keyboard until the DELL LOGO passes from the screen.
5. You will be seeing the BOOT DEVICE MENU.
6. Choose the option--> CD-ROM DEVICE or BOOT FROM CD-ROM.
7. When u highlight it and hit enter on it, the screen will show you PRESS ANY KEY TO BOOT FROM CD.
8. Hit enter Immediately on that screen without missing it otherwise all the step will be repeated back.
I'M ATTACHING FEW LINKS FOR YOU SO THAT YOU CAN DO THAT EASILY AND LEARN AS WELL SO THAT YOU MAY HELP OTHERS AS WELL. SO YOU JUST HAVE TO COPY AND PASTE THE LINKS GIVEN AFTER EVERY STEPS TO DO EVERYTHING SO EASILY.
9. Next screen will show --> WINDOWS SETUP, Set up is inspecting your hardware configuration AND THEN set up is loading files.
http://content.techrepublic.com.com/2346-10878_11-5181-1.html
10. When u see the WINDOWS XP PROFESSIONAL SETUP SCREEN.
http://content.techrepublic.com.com/2346-10878_11-5181-2.html
To set up WINDOWS XP now, press ENTER.
11. On the LICENSE AGREEMENT SCREEN hit F8 to accept the LICENSE AGREEMENT.
http://content.techrepublic.com.com/2346-10878_11-5181-3.html
12. Now the Screen will show u the EXISTING PARTITION on your computer so select one at a time and then hit D to DELETE the partition and if it askd for confirmation then hit ENTER to confirm DELETION of the partition. Delete all the EXISTING PARTITION until you see just UNPARTITIONED SPACE.
http://content.techrepublic.com.com/2346-10878_11-5181-4.html
13. When all the partition are deleted then HIT ENTER to INSTALL.
14. The next screen will ask u to CREATE PARTITIONS so its up to u how many partition u will create. Well i will strongly recommend 2 or maximum 3 partitions. So choose the size accordingly.
Create C PARTITION of 20480 MB.
http://content.techrepublic.com.com/2346-10878_11-5181-5.html
15. When u r done with creating partition then just hit ENTER on the NEXT SCREEN and make sure that the HIGHLIGHTED PARTITION IS C ON THE SCREEN.
http://content.techrepublic.com.com/2346-10878_11-5181-6.html
16. Now you will see the FORMAT PARTITION SCREEN so choose the option FORMAT THE PARTITION USING THE NTFS FILE SYSTEM.
http://content.techrepublic.com.com/2346-10878_11-5181-7.html
17. Now time to GET SOME TEA OR COFFEE DUDE because now you will see the SET UP IS FORMATTING THE PARTITIONS so we have to wait few minutes.
http://content.techrepublic.com.com/2346-10878_11-5181-8.html
18. Next Screen Will Show u that SET UP IS COPYING FILES with a moving yellow bar.
http://content.techrepublic.com.com/2346-10878_11-5181-9.html
19. Keep yourself busy with the COFFEE MUG DUDE.
http://content.techrepublic.com.com/2346-10878_11-5181-10.html
20. Now u juss have to sit and relax for next few minutes.
http://content.techrepublic.com.com/2346-10878_11-5181-11.html
21. Get one more coffee for yourself my friend.
http://content.techrepublic.com.com/2346-10878_11-5181-12.html
22. On the Regional and Language Options Screen you just have to click on the NEXT BUTTON on bottom right hand side.
http://content.techrepublic.com.com/2346-10878_11-5181-13.html
23. On the next screen you need to fill the required details as you would like my friend and then click next.
http://content.techrepublic.com.com/2346-10878_11-5181-14.html
24. The next step may or may not come in your screen which is to enter the PRODUCT KEY for the WINDOWS XP as we will use the OPERATING SYSTEM DISK which i believe u must have got from dell but in case you got this screen enter the PRODUCT KEY and click next. It would be located on the DISK COVER or on the BACK OF YOUR DELL DIMENSION 4600 on a WHITE BAR CODED STICKER AND IT WOULD BE OF 25 DIGIT ALPHANUMERIC.
http://content.techrepublic.com.com/2346-10878_11-5181-15.html
25. The next screen is of Computer Name and Administrator Password. You just have to enter the Computer Name and leave the Administrator Password Box blank and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-16.html
26. The Date And Time Settings screen will come up so kindly choose the correct date and time settings with TIMEZONE.
http://content.techrepublic.com.com/2346-10878_11-5181-17.html
27. Now the time will come when you may go and have a burger because this process will take nearly half hour and will keep showing you its progress my friend.
http://content.techrepublic.com.com/2346-10878_11-5181-18.html
28. Network Settings Screen don't bother yourself and concentrate on the burger and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-19.html
29. Workgroup and Computer Domain Screen so click next only.
http://content.techrepublic.com.com/2346-10878_11-5181-20.html
30. Display Settings or Resolution Screen.
http://content.techrepublic.com.com/2346-10878_11-5181-21.html
31. Don't even bother if these screen don't come up.
http://content.techrepublic.com.com/2346-10878_11-5181-22.html
32. Bill Gates Thanksgiving Screen. Click next.
http://content.techrepublic.com.com/2346-10878_11-5181-23.html
33. Windows Updates Screen. So choose first option.
http://content.techrepublic.com.com/2346-10878_11-5181-24.html
34. Click Next If u got this screen which most probably you will not.
http://content.techrepublic.com.com/2346-10878_11-5181-25.html
35. Internet Settings Screen. Choose the second option saying No this computer will connect directly to the internet and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-26.html
36. User Account Screen. Please quickly create the user accounts.
http://content.techrepublic.com.com/2346-10878_11-5181-27.html
37. Thank You Screen.
http://content.techrepublic.com.com/2346-10878_11-5181-28.html
38. Welcome User name Screen. So choose your user name and log in.
http://content.techrepublic.com.com/2346-10878_11-5181-29.html
39. WINDOWS XP RE-INSTALLATION COMPLETED.
http://content.techrepublic.com.com/2346-10878_11-5181-30.html
SO NOW YOUR NEED TO INSTALL THE DRIVERS FOR AUDIO, VIDEO, CHIPSET AND NETWORK WITH THE DELL DIMENSION RESOURCE CD i.e. Drivers And Utilities CD. Or visit the following link from any other computer and DOWNLOAD the drivers and put it onto a USB PEN DRIVE OR A CD and then install it on to your DIMENSION 4600.
LINK FOR DRIVERS
CHIPSET DRIVER
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R58201&SystemID=DIM_P4_4600&servicetag=&os=WW1&osl=en&deviceid=3268&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=27&fileid=70069
VIDEO DRIVER ( U NEED TO CHOOSE THE SPECIFIC VIDEO DRIVER)
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
NETWORK DRIVER FOR INTERNET
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R67150&SystemID=DIM_P4_4600&servicetag=&os=WW1&osl=en&deviceid=2834&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=87106
AUDIO DRIVER
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R94481&SystemID=DIM_P4_4600&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=4&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=122481
Posted on May 25, 2009
  • Vick
    Vick May 26, 2009
    MY SOLUTION MIGHT LOOK SO LONG BUT WHEN YOU START FOLLOWING IT YOU'LL COME TO KNOW MOST OF THE STEPS TAKES JUST SECONDS AND ONLY FEW OF THEN TAKE A MINUTE OR TWO THE WHOLE PROCEDURE WOULD NOT TAKE MORE THAN 50-55 MINUTES..
    TEM'ME IF THAT'S HELPFUL FOR YOU OR NOT...
    President:
  • 1,185 Answers
Before you touch a key have you made all of the backups of any files you need and have you got the installation discs for both the operating system (XP ?) and the Motherboard plus any other hardware you have installed.
Are you trashing your PC because it has a fault or a virus on the hard drive.
If it is a virus you really need to format it in a clean PC before you re-install Windows.
Once you have made your mind up to do a format with a virus free disk then you will need a bootable copy of Windows.
Start the PC hit F2 to get into the Setup BIos screen
Change the 1st boot device to be the CD Rom , Save and Exit
Insert the Windows disk into the CD drive and do a re-start it will prompt you if you wish to format the hard drive say yes (Quick Format)
Follow the prompts and make note of any messages given
The machine should come back to life but will need the Motherboard disk inserting to install the correct drivers for video etc.
If you are not really up to speed with PC's I would ask someone who is to do this work as you can have many hours of hard work ahead of you if something does not install correctly
    Sergeant:
    Champion:
  • 212 Answers
Click start,my computer, look under hard disc drives, find your hard drive, right click on it, look down find format and click on it.
My power slide button is not working its real loose so how do I open my compture with out breaking my compture I need to titin my compture
What IS a power slide button? What does it do?
You're asking about opening your computer? DO NOT do that! Only one in ten thousand of us could open it and do anything successfully to it.
Aug 07, 2014 | Cars & Trucks
My millemmium gamepack bearware will not reinstall on my compture systerm it use to run on my old compture systerm that had windowa xp on it
There are some games and a lot of other sofrware that will not run on newer microsoft OS like windows vista, 7 and 8.
Jan 12, 2014 | ValuSoft Bearware Millennium Game Pack for...
I cann't access on my compture
if you are using it in a cellphone it is probably locked, try to find in your device memory card settings and unlock it
if it is from camera, try to download data via camera cable, then format it in your computer, then it should work in both devices
Jun 21, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
What board do I need to make my connection to my comptur
It all depends on what kind of copier you have???? There all different..
Jan 12, 2013 | Office Equipment & Supplies
Compture is on but nothing on the monitor. Monito...
Try to check the power supply at the back of your computer that they have works normally if the fan are not punctioning so it means your power supply are damage. But if they works just checked the connection inside or clean the RAM's pin by wiping of pencil eraser or rubber. Or check the processor that they dont have any overheat, just hold the heatsink of the processor and if it is very heat so your processor is damage.
May 20, 2010 | Acer AM5641-B5560A Desktop PC & Monitor...
My clock on my compturer is half hour fast
Double click on your clock in the lower right of the screen on the task bar and correct the time.
May 20, 2010 | Computers & Internet
My compture workes sometimes and sometimes it dont.the power button was dented in after a rock fell on it. it seem like it may be a short in the power button . i am using the end of a pincle eraser to turn...
The motherboard has a pair of pins that is connected to the switch. The switch is a momentary contact, and when depressed the motherboard detects the momentary contact and starts up.
You can use any momentary contact switch as a replacement
Aug 12, 2009 | Gateway Computers & Internet
I need itune setup for v3i motorol what to do?
if you need itunes setup on the phone you will need to have itunes on your compture desktop.
and it will set it up atomatically
Jan 11, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Dell Dimension 4600 PC Desktop Logo
259 people viewed this question
Alun Cox
