Question about Canon PowerShot A540 Digital Camera
Stuck in camera mode, little switch fell off.
The little switch on the top right hand side that switches the camera from view mode to camera mode broke off and I can't find it. If I look inside the remaining hole there is a little (tiny) lever thing. I tried to move it but no luck. Anyone know how much this should cost to fix? Ritz Camera is already trying to sell me a new one. I'm so mad at myself!
  • Anonymous Nov 07, 2007
    Mine was missing when I picked it up today...it hadn't even been dropped! I, too, can't seem to switch it over. Is there somewhere to order the part?
    Guru:
  • 1,894 Answers
Has anyone tried a hard reset on their camera by removing the main power batteries for 60 seconds and the reinserting them as if it were the first time power up. This may not fix your particular problem, but when the processor that runs all of the electronic features of the camera gets confused, this is the best way to clear its confusion.
page number 114 of your manual. tell me if this works
Posted on Dec 22, 2007
Just bought a nikon af l35 camera. Is it just a point and shoot camera? Wondering what the little switch on the front is for left hand side top as you look at it and the little switch on the side of the...
The self-timer lever is on the front of camera, to the left. The switch on the side of the lens is the backlight compensation lever.
You can download a copy of the manual from
http://butkus.org/chinon/nikon/nikon_l35_af/nikon_l35_af.htm
Feb 11, 2011 | Nikon L35 AF-Beautiful point&shoot 35mm...
I pressed the "on" button
Move the slide switch on the side of the card.
Feb 01, 2011 | Cameras
It says off and thats all
CD stuck in player.
Unplug.
Remove lid, small black screws on side and along the top of the back.
Fiddle with latch on left side near front that controls the door.
Once latch is released, open door and remove all CD's.
Make sure 2 CD's are not **** in player.
Move CD cage carefully. It should run smoothly along. If not it is locked in 'switched off mode' or CD is stuck half in and half out. If CD stuck fish CD out carefully.
Plug back in without any CD's in.
System should run back and forward and then lock at left hand end.
Put lid on and try one CD in one slot.
Dec 27, 2009 | Technics SL-MC6 CD Player
Camera does not start up until after several
If you are sure that your battery if fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Nov 11, 2009 | Olympus Stylus Verve / ?-mini Digital...
Hard Time Turning On
For viewing you must turn to the right, it means your switch for record on is defective.
Your Canon repaircenter can fix this for you, if not contact Rotronica in the Netherlands for repair.
Apr 19, 2009 | Canon PowerShot S3 IS Digital Camera
Sanyo VPC-E7 digital camera
Your Probleum is Sometimes occer when camera is put in pocket and press som keys then first on camera they shoot photo.you put to little pushing with the help of hands and then turn up and down you see your camera would worked again.
Nov 09, 2008 | Sanyo VPC-E7 Digital Camera
Fuji a345 digital camera will only take video footage, not photos
The three position switch for play,camera,video has likely broken. The plastic switch on the outside has a small contact plate held to the back of the switch on the inside with one small screw. I do have a replacement on hand if you are interested.
Jan 26, 2008 | Fuji FinePix A345 Digital Camera
HP Digital Camera - M425 - Stuck in review mode, won't switch to capture mode
I just fixed my daughters camera with this problem. First go to the capture mode and see if the reason you are in review mode is because the camera thinks it is docked. If so, look at the dock port on the bottom of the camera. ( May need to magnify it to see in there ) Look for any green corrosion between the contacts. Her's has this corossion between two pairs of the contacts. I took a jewelers screw driver and scraped out the corrosion and then blew canned air in there to remove it. Turned it on and now it works fine. I have a feeling that the battery compartment is venting through this port and the small amount of acid vapor produced as the batteries discharge is causing the contacts to get this corrosion.
Jan 13, 2008 | HP Photosmart M425 Digital Camera
Manual Exposure mode Nikon F80
1) turn the mode switch/knob on the left of the camera to M ( manual mode ) 2) turn your lens to the highest f-stop ( 22 or 16 depending on your lens ) 3) in front of shutter release button you have control for your aperture : turn until the desired aperture is displayed ( view finder or the LCD monitor on the top ) 4) your shutter speed setting is controlled with your thumb with the control situated next to the strap lug on the right hand side of the camera. 5) press shutter release half way and look through viewfinder and see light meter reading and adjust either shutter speeds or the aperture as explained being guided by the l.meter.
Sep 23, 2007 | Nikon F80D 35mm SLR Camera
Camera Mode Doesn't Work
There is a slide switch on the back of the camera, near the top right corner of the LCD screen. You apparently have it setting on the icon that looks like a triangle. Slide it up to the icon that looks like a camera.
Aug 31, 2005 | Canon PowerShot A75 Digital Camera
Canon PowerShot A540 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
